Hmm seems the bashrc doesn’t work, try placing it into the .profile instead.
Edit the /root/.profile using nano: “nano /root/.profile”. Also change the ones in crontab: “crontab -e”. Run: “su root” or reopen your ssh terminal. Restart transmission: “transmission-stop && transmission-daemon”.
Don’t forget to clear your browser cache else the default theme will load.
You mean remotely? I use the android app Remote Transmission. It launches on magnet URI clicks. You have to forward port 9091 on your router to access Transmission externally.
On the nas itself use “transmission-cli magnet_uri”.
On PC I’m not sure. Previously I wrote a personal program to relay magnet URIs but it was for uTorrent webgui.
I’m abit new to this installation, so far so good (3 months). But I don;t know how to lock my transmission login from outside… If you know the port, you can connect to it and see torrents. This wasn’t possible with previous version, as it was asking for credentials. I’ve entered in settings.json (daemon stopped), rcp-username and rcp-password, but it’s not asked as I browse to my domain.
Could you please help me?
Think you missed out: “rpc-enabled”: true,
Stop the daemon, edit as above and restart the daemon…
any way to install Midnight Commander in this wd device? I’ve tried ipkg and apt get versions, but none of them finished suyccesfully
No problem. I have no plans for MC now. Currently taking my time working on something which allows users to host website such as owncloud and wordpress on WDMyCloud.
But for MC there’s a repo setup by one of our forum user @Fox_exe which you can manually install via apt-get.
Apache2 is already running on WDMyCloud serving the WD Dashboard and remote logins. The big concern is doing custom modifications without breaking WD’s stuffs, which is the reason why I created all these online installer so we don’t have to mess with apt-get and brick the nas :laughing:
WDMyCloud:/# curl nazar.bagus.org/installer.fcgi?transmission_2.84-|sh;
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 185 0 185 0 0 174 0 --:–:– 0:00:01 --:–:– 175 nazar.bagus.org: You 86.121.x.x are the invalid request number 54 since my FastCGI was refreshed and started counting /-:
Anything I need to do ?
Thanks.
PS: I’m using:Current Version WDMyCloud v04.01.02-417 : Core F/W
I don’t usually execute files from the torrent download path in fact I move them elsewhere after seeding. You might wanna try the transmission forum for help.
