Weird connection issues
Hi all.
I have a WD My Cloud EX4 Firmware 2.10.302.
I can only connect to My Cloud if I use my phone’s data plan or through a vpn from my Android phone. If I’m connected to my WIFI (Same network the My Cloud is on) the connection just hangs and I get (Network connection failure 905) with the Android app.
Connections to My Cloud from my Laptop or other computers on the network is fine (mycloud.com or Windows mapped drives).
Is this a known issue?
Maybe you should check in the EX4 forum.
http://community.wd.com/t5/My-Cloud-EX4/bd-p/mycloud_ex4
