Remote access to MyCloud on Live Duo
Got my Live Duo installed and functioning, and have enabled Remote access, but when I try to access it remotely - both via an Android tablet and from a PC browser, I get the error message " Device is Offline. MyBookLiveDuo is currently offline. Check your Internet connection and enable remote access; then try again."
Any thoughts as to what could be causing this would be greatly appreciated.
thanks
SirArch
See if this gets you anywhere:
http://community.wd.com/t5/WD-My-Cloud/HOW-TO-Troubleshooting-Remote-Connectivity-Issues/m-p/617261#M1130
Note:  The images are from the My Cloud NAS, not the Live Duo, but the process is pretty much the same.
Excellent tip. Thanks
Sir Arch
