Hallo,
My mycloudex2ultra is offline.
The leds on the front are all bleu, the device is connected with the cable to my network, when I open the OS5 on my iPhone its says “hello Ton” and then he says “you’re device is offline”
What happens when I do a reset on the back off the device.
(ps sorry for my English its not that good
the IP Adress I can not find it don’t no how ether
is it possible to put the hdd WD RED 2TB in a new NAS system with out any damage
