Defragmentation and cleaning
I’m in the need of defragmenting and cleaning up my WD MyBook external hard drives. They are performing very sluggishly.
I could not find any software of WD’s or functions in the Drive Utilities application that would do this. Is there a WD one for defragmenting and cleaning a drive?
If not, what would you recommend as the best solution for doing this? Software etc… any suggestions and help is much appreciated. Thank you for your time.
Best,
-m
Hi there and welcome to the WD community.
There’s no WD software that has a defrag feature, lets see if another user can help out with a tip or information on this matter.
If you have windows you can defrag the drive using the windows defragmetation tool:
http://windows.microsoft.com/en-us/windows/improve-performance-defragmenting-hard-disk#1TC=windows-7
