i installed OMV 1.17. i could log in OMV just 1 time, after i rebooted the device , it stopped working. i can see the green light, it seems normal, but i cant reach the gui through explorer or i cant reach my device via ssh. i scanned all ip s inside my network but my device does not get an ip. it was working great after reboot it stopped working.
so i tried recovery method. but i receive an error
Hello Fox. Very Thank you for the work.
I had already installed clean debian from other site to my Mycloud, and finished setting up for me to work.
But I found that it was old version you uploaded, and the ‘iptables’ doesn’t work because the kernel’s not changed.
I want to use the iptables by updating the kernel, but I also want to keep my settings because it took really long time for setting my own webdav, ftp, ssl…
Is there any way just I can do without changing those things?
Look in my G.Drive folder - you can find there Kernel v3.2.68
Just unpack modules to /lib/modules and dd kernel to part 5:
dd if=kernel of=/dev/sda5 (On WDMC)
Are there some files missiing from the 3.2.68 modules? There are only 3 files but in the 3.2.26 modules folders there are 12 files. Am I downloading the right file, Linux-3.2.68-bin.tar.gz?
I tried the new DSM5 installation with the HD taken out and connected to a linux box. The DSM is running well so far.
I remember you metioned the poweroff shall be done through ssh instead of the UI. I tried “poweroff” but it said Unable to execute shutdown: No such file or directory.
Thanks Fox_exe! DSM5 running great, managed to get Transmission running through package center too, just had to add http://packages.synocommunity.com/ as Package Sources and enabled home directories under user settings (don’t know if that matters) and just made public directory for the downloads
Didn’t try other community packages yet, they had couch potato etc. I just wish it would be possible to speed up samba a little bit. Quickly tested on small 500MB test file 30MB/s write and 80MB/s read
