When I turn on the device, the wifi LED blinks for about 10 seconds and then turns off. None of my devices are able to discover the devices in the mean time.
I completed a hard reset and it still has the same issues.
I can store files ont he device if I connect it via USB.
HELP. hopefully someone can help . just got a wd my passport wireless pro. heading overseas in 2 days and i cannot get it set up. WILL NOT bring up the wireless icon. help please
Have you got the complete user manual from WD; either on the drive itself or from a download from WD Support? Every owner of the MPWP needs a copy to refer to before even setting it up.
