I bought my passport ultra for mac on amazon by accident but I have a pc and I want to know will work on my pc
Do I cancel my order?
What’s the difference anyway?
The My Passport for Mac is factory formatted Formatted HFS + Journaled macOS High Sierra, Sierra or El Capitan.
See Technical Specs on the Product Page
For use with Windows 7,8,10 … just simply format it NTFS or exFAT (which is compatible with both PC & Mac)
No need to cancel your order, when you get it, just format it.
If you don’t know how, follow the WD Instructions
