hi I’ve purchased a 12TB Ultra EX2, why only has 6TB for using at the dashboard information? thanks for letting me know, really confused!
All Two-Drive Devices are set to Mirror Mode RAID 1 by Default to offer data security. This causes the two drives to work as you would have one drive only.
RAID 1 Mirroring is writing data on both drives but the capacity of one drive is shown.
If one of the both drives fail, you simply replace the broken one and after some time, all data from the good drive is copies onto the blank new one to re-establish the Mirror Mode. This helps to protect your data from a single-drive-crash.
