WDTV Live Hub Drive mapping
I have a new WDTV Live Hub setup on wireless LAN. I used a D-link supported/approved USB Device, it is working fine, connects to internet but i can not map a drive to this device from an XP or Vista machine. I tried the mapping utility but that fails as well. I am able to get to the media device through the web http service on the LiveHub however i want to move files to the media device from my PC. Firmware is upgraded to latest level, Workgroup is set correctly. Any ideas?
I tried mapping drive manually but that did not work. What is the default \device name\folder share I should use.
Could this be a firewall issue?
Could very well be a firewall issue…
If I remeber right the default name is \WDTVLIVEHUB\ or \WDTVLIVEHUB\Public or \WDTVLIVEHUB\WDTVLIVEHUB - I don’t remeber which (I’ve renamed everything)…
hi tried disabling the firewall and changing the device name on WD, still can not see the WD. Can see all other devices/PC’s on the LAN
also, when i reboot, i get the firmware 2 of 2 download fails even though the latest firmware is on the system. under settings, latest firmware shows 2.07.17. then i select check for new updates and the WD says “your media player is up to date”. very confused…is this thing defective.
I would suggest you follow the instructions from this tread.
http://community.wdc.com/t5/Firmware/HOW-TO-Update-Failed-at-Step-2/td-p/233316/jump-to/first-unread-message.
Hi your URL goes nowhere…anyway, i took the unit back because if they cant get a simple firmware download correct, then what else is not going to work.
I also had problems to set up the network, but I did a factory reset and after that, everything worked at once. Wireless is also not the best idea; wired is always better and signal much stronger.
Plomp77
