I am a new user of WD TV Live Plus and got the box two days ago.
The installation was really easy; well done WD.
During installation I upgraded the firmware to the latest version.
I have a 1Tb Element USB storage device and I am glad to say I can play all the video and pictures from the Element hard disk.
However I am having a few problems when trying to play video over the network from my Windows 7 laptop. On windows 7 I have shared all my stuff to “HOMEGROUP”. I am able to play files from “Public” share but can not play from any other folder.
On my Laptop I have a second hard disk where I store my AVCHD (m2ts) files. I able to see the folder and the files underneath but whenever I try to play one of those files then it reports “File type not supported”.
However, if I copy the same file and place it in public folder then there is no problem playing the same video file.
WDTV does NOT support “Homegroups.” You must use WORKGROUPS.
When sharing a folder, you need to share with the user “Everyone,” if you’re logging in using “Anonymous.” If you password-protect the shares by assigning them to other users, then you need to log in to that user account from the WD.
1. Windows 7 laptop in Workgroup (changed from Homegroup).
Folder shared to “Everyone”
Rebooted the laptop
Power down and reboot the media player.
However, the problem still not solved. I am able to select the pho/video files from Windows 7 folder but will not play the files. As I said before I can play the same photo/video files if I copy them in Windows 7 Public folder.
It got to be some sort of permission issue. Any more idea?
By the way; I haven’t installed the “Discovery” software on my Windows 7 laptop. Is that necessary?
May be I need to read the document again. Could you tell me how to map disc on my laptop? I can see all my files on the “D” drive but can not play them.
You are right. I can see the files on the “D” drive on my laptop but can not play them. Reports “file type not supported” or something similar. I can not remember the exact error message.
As I said before, I can play the files if I copy them in the public shared directory.
