WD My Passport Wireless 1 TB: Not charging, no detection to USB connection
Hello, my WD My Passport not charging (using charger) and not detected when I connect it to my laptop. I have try use different cable, but still not working.
Appreciate your assistance.
Hi port,
You should contact WD Support for such an issue. To contact WD support, you can refer to the links mentioned below.
Phone:
https://support.wdc.com/contact_phone.aspx?h=4
Email:
https://westerndigital.secure.force.com/ind/?lang=en
