Here’s one I have a problem with:
General
UniqueID/String : 194980886616302608230041274680214330464 (0x92AFF3EB788DA0848F4C46772A3C9C60)
CompleteName : J:\Movies\English\Golmaal.3.Bluray.x264.720p.DTS-FictionBoy.mkv
Format : Matroska
FileSize/String : 4.37 GiB
Duration/String : 2h 20mn
OverallBitRate/String : 4 468 Kbps
Encoded_Date : UTC 2011-03-13 02:01:50
Encoded_Application : mkvmerge v4.5.0 (‘Speed of Light’) built on Feb 1 2011 02:10:32
Encoded_Library/String : libebml v1.2.0 + libmatroska v1.1.0
Video
ID/String : 1
Format : AVC
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
Format_Settings_GOP : N=1
MuxingMode : Header stripping
CodecID : V_MPEG4/ISO/AVC
BitRate/String : 3 701 Kbps
Width/String : 1 280 pixels
Height/String : 576 pixels
DisplayAspectRatio/String : 2.222
FrameRate/String : 24.000 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.209
StreamSize/String : 3.54 GiB (81%)
Title : Golmaal 3 720p
Encoded_Library/String : x264 core 114 r1913 5fd3dce
Encoded_Library_Settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3701 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language/String : English
Audio
ID/String : 2
Format : DTS
Format/Info : Digital Theater Systems
CodecID : A_DTS
BitRate_Mode/String : Constant
BitRate/String : 755 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Compression_Mode/String : Lossy
StreamSize/String : 756 MiB (17%)
Title : DTS 768 5.1
Text
ID/String : 3
Format : UTF-8
CodecID : S_TEXT/UTF8
CodecID/Info : UTF-8 Plain Text
Title : English
