i have recently purchased wd tv live plus. i connected it with wifi when i go on to youtube .file keep on loadind but didnt play and i played several movies from network shared drive.it played well and when i play again those file it keep on loading but not playing it?please tell me the solution. if i update the firmware …can i come to its orignal setting if i want to?means that can i came back to default firmware?
yes i have checked it. its playing vob file but when i play mkv.it previously played fine…now its keep on loading
Ah – you’ve played a “bad” MKV file (one made by MKVMerge greater than 4.0).
You need to delete that file and/or remake it (with a version of MKVMerge 4.0 or earlier). In the meantime, completely reset your Live and DON’T play that file (or any other MKV file made with a bad version).
thanks …it works
