Hi all,
I am getting below error when trying to login into Mycloudex2
Power was lost from the system. Performing file system consistency check
I have WDMyAccess installed on windows 10. Even trying to shutdown from there does not seem to do any change. There’s blinking blue light at the top.
It’s going on since 2 days. I have 2 TB usable capacity on 4TB disk due to RAID set up and there’s roughtly 700GB data.
Any help in this regard will be appreciated.
              The file system or RAID volume may be corrupted or compromised due to a power failure and the unit is trying to repair the damage. I’d recommend being patient and monitoring the progress from the unit’s Dashboard as opposed to the WD Access app.
              Thanks Trancer.
The main problem is I can’t access the unit dashboard. If I can login and check progress of consistency check. it would be easier to have patience.
Does this forum have any official support ?
Regards
Shiv
              The WD Community is a User Forum. WD Staff and personnel may post once in a while, but the WD Community is a not a direct support channel.
I’d recommend sending an E-mail to WD Support about this. You can do so in the following link:
http://support.wdc.com/support/case.aspx?lang=en
              Thanks Tracer. I have raised a case on the link given.
