PAN/AM Recovery ISO fails to create USB Drive for DX4000 recovery
Good Morning,
I came to work yesterday to a unreachable WD Sentinel DX4000… The error on the LCD was "STARTUP FAILED: 0xD9. After researching the error I found the recovery instructions along with the following ISO file to download “DPANAM_SvrRecovery_1_7_6_20.iso”… However I am experiencing a weird issue when attempting to create the USB Drive using the downloaded ISO
Prior to starting the setup, I can see the removable USB drive listed with a drive letter in the “My Computer” file manager, BUT upon stating the setup and following the step, as soon as I check the box that say “I understand that all the data on the USB will be erased” and I click the next button, I get an error that states USB can not be created, fix this problem
When I look back at the “My Computer” the USB drive is gone… to restore the USB I must reformat it
I have tried this with several different computers and USB drives with the same result…
Any assistance would be appreciated… Is there another way to access the data on the drives using a different enclosure?
Thanks in advance
I don’t remember the error but the other day I tried it and it said “something” I just went back and clicked recover again and it worked the second time.
If you do not have a backup of your data and you need your data you prob should try to get your data back before doing a recovery. If it is 2 drives raid one you should be able to slave a drive or use a usb dock and see your data. If it is 3 or more drives raid 5 you will need some sort of raid recovery software like for example
Thank you Gramps… I tried it several times without success.
I was concerned that since the device was running windows 2008 server essentials that I would not be able to access it…
So if I purchase a NAS box with USB interface and use the software you reference above, I should be able to transfer data to another disk… right?
A NAS box will not run that software. NAS boxes are now Linux, you can use any desktop PC to run the raid recovery software. Most have a show your files for free, if you see them, then you pay for the software and can drag and drop
You need to verify your download with a hash file. Many problems come from bad downloads
you do not have a 3rd party antivirus that may be watching the thumb process?
How big is the USB drive? You want to use a drive 16-32GB in size.
https://support.wdc.com/knowledgebase/answer.aspx?ID=9889
