Im using Windows 10, i have OpenVPN residing on my router and the Mycloud mirror sitting on the same network. I can map a network drive when im connected to the local network and can gain access to the files on the NAS after ive entered in my credentials. When i use OpenVPN on my laptop (yes, i am connected properly, i can see other devices on that network) and i am on a different network i can no longer gain access to those files. Now heres the kicker, the same OpenVPN file i use for my laptop i use for my android phone(this also works for apple). When i remote in and use ES file Explorer (its a different file explorer for apple) and scan the LAN, my NAS shows up, i enter my credentials, and im in.
Is windows explorer to blame? Why can i remote in on my phone to see the NAS but not my laptop?
Please help, ive found similar issues on this site but with no resolve.
Thanks!
Hello, did you find a solution to this? I have the same problem thansk
