I just added a WD MyCloud on my shop lan, works fine.
When at home I can use WD My cloud app to see all the files down in my shop, works fine.
But I can not seem to map a drive letter to the WD Mycloud from my remote machine. Kind of important as I have apps that use data off the the shared drive. I typically use Z: and P:
Did I miss some important setup or code install? I really need to map two drive letter on my remote macchine to shares on the My Cloud.
Thanks,
Bob K.
