Need help to find 8TB red drive for my PR4100
I recently purchased a empty PR4100 and moved my 2 8TB red drives from a PR2100 into it. Now I want to increase my capacity and buy 2 additional 8TB drives. The PR4100 detail page states compatiable 8TB drives are WD80EFAX and WD80EFZX. (https://support-en.wd.com/app/products/product-detail/p/139#WD_compatibility)
I couldn’t find them on WD website. I only find Red pro 8TB 256MB WD8003FFBX, Red plus 8T 256MB WD80EFBX and Red plus 8TB 128MB WD80EFZZ.
Can someone direct me to a compatible drive? Thank you.
This is the respone I got after posting the same question to WD support.
"I understand your concern that you want to compatibility with your PR4100. I am sorry for the inconvenience caused to you.
Based your query, please allow me to inform you that your drive are compatible with your device. "
WTH??!!
Hi @PYeung,
For information you can refer to the below mention link:
Product Brief: WD Red Plus (wdc. com)
Not an easy site to navigate. This is the drive you need:
