MyCloud Home Flashing Light - No Connection?!
Hello guys,
About had enough of this thing and about to send it back. When the light is stable I cannot find it through mycloud home it appears on my network but can’t do much with the IP. When I try to 40 second reset it it just flashes constantly. So I’m stuck with either a stable light that does nothing or a light that constantly flashes when reset. I think it’s bricked?
  • Check your router to determine if it has an IP address
  • if yes, the unit is in a fault state
Fast Breathing
Device Requires Attention - Device Encountered an Error
USB Device Connection Error
Ethernet Connection Not Available
