My Cloud network issue
My WD Mycloud was working fine until a few days ago. It has a pretty much static yellow LED (blinks every few minutes, though) and the LAN cable LED on the back is flashing green all the time. However, I can’t access the unit, nor can I “discover” the unit using the WD software. It sounds like the HDD is working inside and even seem to make a very quiet read/write noise.
I’ve tried the usual reboot (4s and 40s) , but to no avail. I have also checked the LAN cable by swapping and even moved the box to another room and connected to a different CAT6 outlet. No luck!
Any tips or ideas?
Thanks in advance.
Hi NickB1,
The link below will allow you to call support.
Thanks Brandon, but an utter waste of time::angry:
Thank you for contacting Western Digital Customer Service and Support.
I am sorry you have encountered this issue , more specifically you cannot access My Cloud device. I am going to ask you to clarify a few points, so we make sure we resolve the issue.
Since you have done the troubleshooting, I will not ask for more steps.
In case your drive worked fine with Windows 10, I assume it has failed.
Since there is no warranty unfortunately I will not be able to offer a replacement.
If you have any further questions, please reply to this email and we will be happy to assist you further.
