Good afternoon, first, sorry for my english,
I wrote this post here because I see it as last chance…
I had also email communication with WD support but didn`t find any help solution, read forum here but people have same problem I see but without solution
I will describe problem:
(First very short describe - blue LED on front side is blinking all the time, cant stop after one week of continuous work, cant reach drive anymore)
I have WD My cloud 3TB, bought November 2016, everything worked perfect, I used it everyday for watching movies for my son.
Every midnight it wakes up and syncronize or something like that, after 10 minutes came back to sleep mode until i play again any movie…
Problem starts in December last year when I came to room and listen disc is working at unusually time and work all day…
It didn`t came to sleep mode whole day… I saw on front side blue LED is blinking all the time… Wait 3 days if something happened but no result.
I cant reach drive from my TV, android box, PC, I dont see it anywhere, every device wrote its not accessible.. I cant connect on PC to drive - write me it`s offline (home internet and rest of devices works perfect)
I have read all posts about this problem on all forums but didn`t find answer. Then i changed lot of emails with WD support and they gave me these answers to fix my problem:
- connect My cloud directly to PC - can`t see it as a drive - in browser shows it as offline drive
- make 4 seconds reset - done, without change
- make 40 seconds reset - done, nothing changed
- check backside LED colour - everything ok
- changed cables - no change
- I wait one week to “finish” firmware update (WD support idea) - nothing changed (I wait 9 days in this mode, when disc was working and front LED blinking blue - reason? WD support wrote wait because it`s indexing)
- next email from WD support: take off drive from cover and connect it with SATA to PC and use some LINUX program in link they sent - didn
t try yet because Im afraid of damage and never use LINUX, don`t know how to use it… - suggest from support: in case this doesn`t work - contact one of our DATA RECOVERY PARTNERS
That`s all support from WD ![]()
I turned it off during christmas time and affraid it turn on… Im sad, I think I lost all my data, cant connect anywhere and disc is still not working - still blinking blue LED on front and not reachable… I`m very dissapointed that this happened with disc which has to work more than 2 years ![]()
Do you have any solution to my problem? Tell me please whats happened with My cloud that I cant see it anymore and LED is still blinking after connecting to power? thx
