MKV issues - header compression already removed
Hi all,
Am having dramas trying to get a MKV file to run on my WD Elements Play 1TB.
Initially when pressing play nothing happened cept a blank screen. I checked the forums and via mediainfo found header stripping had been used. So I used mkwdclean --optimize on the file. Now when clicking play I recieve a “File is not supported error”
Mediainfo details below, but to my newbie eye it looks like the audio and vid codecs are supported and it should work.
Grateful for any advice.
General
Complete name                    : H:\Red.mkv
Format                           : Matroska
File size                        : 4.37 GiB
Duration                         : 1h 51mn
Overall bit rate                 : 5 625 Kbps
Encoded date                     : UTC 2011-01-07 07:54:06
Writing application              : mkclean 0.8.2 ou from libebml v1.0.0 + libmatroska v1.0.0 + mkvmerge v4.4.0 (‘Die Wiederkehr’) built on Oct 31 2010 21:52:48
Writing library                  : libebml2 v0.21.0 + libmatroska2 v0.22.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L3.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 51mn
Bit rate                         : 4 988 Kbps
Width                            : 1 280 pixels
Height                           : 528 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.308
Stream size                      : 3.78 GiB (87%)
Writing library                  : x264 core 112 r1834 a51816a
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4988 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 51mn
Bit rate mode                    : Constant
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Compression mode                 : Lossy
Stream size                      : 509 MiB (11%)
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : English
Thanks.
If I remember correctly, last summer/fall people all over the internet were having issues with mkwdclean.exe being buggy and not working properly, and files not being playable.  I’ve never used it myself.
Try just re-muxing the file itself using MKVMerge GUI from the MKVtoolnix package.
Select “Compression → NONE” for each and every track under the “Extra Settings” before clicking the re-mux button.
Thanks RoofingGuy. You were spot on, I re-muxed the file using MKVMerge and the file was then playable.
Cheers,
Gonad
You’re welcome, Gonad.
In the future, you might find this program useful: MKVFix
It’s an application someone wrote to scan through your files, looking for any with compression in the headers, and it can automatically call MKVMerge and re-mux any that need “fixing”.
The only “catch” is that it was written when 4.3.0 of MKVToolnix was the current version.  I don’t know whether it will work properly with your version 4.4.0.  I believe people were definitely having problems trying to use it in conjunction with 4.5.0 and above and they had to downgrade their MKVMerge version.
Just in case, here’s 4.3.0 which definitely works with MKVFix for scanning and remuxing “bad” files: v4.3.0 of MKVToolnix
Fantastic RoofingGuy. I was just looking to do up some dodgy script so you’ve saved me a heap of time. I’ve tried out MKVFix and it’s exactly what I was looking for to do the rest of my collection.
Much appreciated,
Gonad
