Hi. Can somebody tell me why are this MKV files not playing smoothly from my collection? Audio/Video is playing like a slideshow from LAN/USB? Should I use 3D glasses for all MKVs? … Ive tried with all fw versions, but THE ISSUE still present.
thanks for looking.
Good Job, WD and sorry for my english.
Format : Matroska
File size : 1.35 GiB
Duration : 43mn 34s
Overall bit rate : 4 437 Kbps
Encoded date : UTC 2009-12-05 09:45:12
Writing application : mkvmerge v2.9.8 (‘C’est le bon’) built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=Unknown@3.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 34s
Bit rate : 3 965 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.179
Stream size : 1.21 GiB (89%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 43mn 34s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 120 MiB (9%)
Title : DD 5.1 384Kbps
Language : English
Format : Matroska
Duration : 43mn 34s
Video
Format : AVC
Duration : 43mn 34s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 43mn 34s
Bit rate : 384 Kbps
Language : English
