my wd live player has problem with this file:
Format : Matroska
File size : 17,1 GB
Duration : 2h 10 min.
Overall bit rate : 18,9 Mb/s
Encoded date : UTC 2010-01-09 15:31:42
Writing application : mkvmerge v2.0.2 (‘You’re My Flame’) built on Jul 16 2008 20:03:58
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Wideo
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : No
Format settings, Matrix : Default
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 2h 9 min.
Bit rate mode : Zmienna
Bit rate : 18,1 Mb/s
Nominal bit rate : 35,0 Mb/s
Width : 1.920 pikseli
Height : 1.080 pikseli
Display aspect ratio : 16:9
Frame rate : 23,976 kl/s
Resolution : 8 bitów
Colorimetry : 4:2:0
Scan type : Progresywny
Bits/(Pixel*Frame) : 0.364
Stream size : 16,4 GB (96%)
Title : PID 4113
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Stała
Bit rate : 384 Kb/s
Channel(s) : 6 kanałów
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48,0 KHz
Stream size : 357 MB (2%)
The file freeze, run, freeze, run… on wd live. I tested the file on my computer and everythig is ok.
