Model SDPS314-002T
At first, this light would go off and disconnect every time I touched the drive. With trial & error, I discovered that the cheap USB-C cable that shipped with the drive was bad.
I swapped out the cable, but the damage was done. Tried several cables, and different ports on different Macs. No luck.
Any saving this thing? Seriously disappointed in the quality of this product. I lost some important data.
I suggest running First Aid on the drive to see if it can be repaired. Otherwise, many data recovery tools can sometimes retrieve data from damaged drives.
Thanks for the reply.
I forgot to mention that it doesn’t even show up in Disk Utility, so I can’t repair it.
I installed the SanDisk Recovery app and it couldn’t see the drive either.
Feels like the drive is fried, but willing to try anything to save it.
