Insert USB with Firmware for WD TV Live Media player
My WD TV live (Model WDBAANOOOONBK-00 has stopped working. When powered on the only message on the screen is “Insert a USB drive with firmware to recover your WDTV” I have downloaded the firmware but the device does not read the USB on several attempts. What do I need to do?
Moses
Search Google for I believe 2.21 or something download extract t it to a fat 32 USB drive place in back of devices USB slot. Show update or show new firmware click and update even if it’s a down grade. This firmware seems to work best. Good luck.
That only appears on a WDTV that has successfully booted
The “Insert a USB drive with firmware to recover your WDTV” is a pre-boot error message.
There’s plenty of previous posts regarding this problem … the one below found by searching this forum is probably the most relevant to the OP’s problem.
