I’ve just recently purchased a WD Caviar Blue SATA 3 internal hard drive for my PC (AMD athlon 64 X2 Dual Core Processor 3800+) as my old internal HD failed on me (had it for around 6 years). I plugged in the new WD HD but the Bios does not recognize it. I can hear it spinning up so the power cable works, I have tried two different sets of SATA cables on all 4 ports on the motherboard, tried to vary the odd jumper settings after having none for the first few trys but no luck. I don’t have another PC using SATA to try it out on however I do have 2 old HD’s which I have tried and they register as the Master and slave IDE. The slave wont load because its so old it has no memory (used Windows 95 on it) and my master IDE seems to get stuck on loading up Windows ME and I can only access it on safe mode so I can’t look in the add hardware section of the control panel in safe mode.
I have thought about wiping my master IDE and putting Windows XP on it but I’d like to avoid that if possible. Any suggestions on what else to test, jumper settings, cables etc would be appreciated? Thanks
