Hello. Here we have a 24Tb G Speed Shuttle with thunderbolt 3, we’re having issues with the Mac Pro (2013): the computer appears to not discover the drive.
We have installed the drivers and we’re using a usb c/thunderbolt 2 adapter. Is it possible that the Mac doesn’t recognize the drive?
You need to have Thunderbolt 3 Type-C connector on you Mac Pro for it to see and configure the device RAID. If not, you will need to order drives preconfigure then insert them in to your Shuttle for it to work with Type-C to Type-A connection on your Mac Pro.
