Background, I had set the mycloud NAS at my friends house and now I have moved it to my network at home. It was running properly when I first plugged it in. Now I have several issues, first being this screenshot.
The capacity not rendering. I have maybe 80 GB of files on this NAS, and its an 4TB capacity NAS.
Anyone got a fix for this? I will post some more issues on another thread once I get this resolved.
how long have you let it set? i have seen this occasionally and it generally corrects itself, if not try a reboot. from my experiance it doesn’t really indicate an issue, just a fairly poor web interface design.
what is the status of the 3 LEDs? 1 front, 2 back?
what other issues are you having?
when you moved the drive did you shut it down cleanly from the UI page?
It looked like i had to get rid of all my other users, shares and then rebuild the database, and because i had 70 gigs, i guess it took awhile before the scanning and build took awhile. solved i guess.
I feel bad for you as I had to do the exact same thing, which is UNACCEPTABLE.
C’mon WD, FIX THE SOFTWARE lest you lose more customers. I’m now on a social media mission to broadcast as loud and far as I can how BUGGY this product is today. I have simply lost my patience with this product. Too many issues.
This is marked as Solved, but it is not solved! The firmware released on 12/17 seems to have caused a huge issue with the drive. Please, if this is solved, direct me to the solution.
Same here. This is NOT resolved on my end either and I did all the suggested fixes from the moderators.
