CF card import on My Passport Wireless Pro
I’m having trouble getting the My Passport Wireless Pro to work with my card reader and CF cards.
I’ve successfully set the device up to auto import from the SD card and the option for USB is also checked. but when I plug in my card reader and insert my CF card, nothing happens. What am I missing?
The MPWP works fine with the latest firmware. I use a card reader (USB 3 reader, but not sure that matters) and plug in the CF card. The download usually starts automatically but in a few instances I have to press the button to start the download. The files (including Canon CR2 Raw fies) are then found on the drive in the USB download file.
