CCTV WD Hard Drive Recovery HELP
Hi all,
I was recently burgled and my CCTV system had stopped working, but there is a small chance that the camera caught some footage.
I have removed the hard drive from the recorder and Im trying to access it as an external hard drive on my computer, but I can’t seem to get it to be recognised.
The hard drive is a Western Digital 1TB purple SATA
I have plugged it into my external HDD converter, and plugged it into a Mac and also Windows 10 machine but can’t view any of the files.
The drive can be seen, but I can’t mount it or accesses it to view anything.
Appreciate any help with this, hoping someone else might of had this issues.
Thanks in advance,
Si
I have exactly the same issue, were you able to find a solution to this? A way to mount the disk in Windows or Linux, have the partition recognized and be able to copy folders or videos from the disk?
No luck yet, im hoping someone on here can help?
no answer yet… hope tomorrow could be an answer…
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
