4tb wireless pro car charger?
I plan on using the unit in the car often… My question is car chargers… Is there a good one to use or a recommended unit?
Hi ondarocks,
Unfortunately, Western Digital doesn’t manufacture Car chargers. However, we recommend to use 12 Watt Adapter with My Passport Wireless Pro device.
You are basically asking about traveling with your MPWP, so you need to know some basics about chargers and portable battery chargers.
I travel often with my MPW, iPad, Phone, etc. They all have the same basic requirements; they need an input of 5 volts (5v DC), and either 2 Amps or 1 Amp current requirement. Your charger for MPW is 5v, 2 Amps which is same as an iPad charger and others. You can charge an MPW with an iPad charger and vice versa. The important thing to know is these gadgets need 5v exactly. but the amp requirement (A) varies depending on size of device (phones require less amps than tablets and drives). And of course,you need the appropriate USB cable to plug into the device you are charging.
You can either use a charger plugged into an electric outlet or do as I do, use a portable battery with the correct (5v, 2A) output.
I use chargers and batteries made by either Anker or RAVPower. Both are quality units and both are sold by Amazon. A battery rated at 22000mAh (milli-amps per hour) is likely to be sufficient, but you could get a higher rating above 22000 for one that lasts even longer. Beyond this point it is about how much you want to spend.
RAV products:
https://www.amazon.com/s/ref=nb_sb_ss_sc_1_9?url=search-alias%3Daps&field-keywords=ravpower&sprefix=rav+power%2Camazon-devices%2C299&crid=YSVPICE2W3DE
Anker products"
https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=anker&rh=i%3Aaps%2Ck%3Aanker
Thanks for your answers!! I am adding a custom USB charger port inside the console compartment… Just needed the proper specs!
With appreciation!
Richard
SO this is all you need or the one port model:
https://www.amazon.com/RAVPower-Charge-4-Port-Charger-Galaxy/dp/B01LCFEQM4/ref=sr_1_13?ie=UTF8&qid=1521737400&sr=8-13&keywords=ravpower
I put a 4-port in our car’s console
