Whitelist problems
Hello
I want to rebuild a DX4000 with new drives. I have read up the threads, downloaded EMEA_SvrRecovery_1_7_6_21_.iso, extracted the files with NHC Experss Zip and built a 16Gb Kingston USB key O.K.
On the key I can find the WDRECOVERY folder and the 2 files WhitelistK.XML amd WhitelistS.XML.
When I try to open them with Notepad to edit in a new drive type they appear to contain rubbish.
I have done this twice
Any Ideas what is going wrong
Whitelists.xml below.
=”t£/]’ÇÊ4ãøs£¸>G ÜñÂÙ-ò”àŒÊ8˜®•R6
¼ë¿[sÀyGÏïÇu»jVÚZhäžúHf H·Ô²“„ÏÒƒäA9b†Ú?-¨$Nc_J^×V4ú0ÕŽGôó†ÉµØ³.c/=ÓözÖ$QÊÔ:H8?.sKï´°Õ”í]´c/µ;Æ+Ò}Á\øc6ÃËØ!€ÇKÏšøH32 oüy°¢Ç$H”jú2E-ßO’ÁŠ$b›(˜žÒçK/‡S+•]o{w×ík\À®6_ZN
GÕ—&? a
Z—¢
¨ù~LžÂÑNµtVm€oãIúUêqÝÚðl›TÓšÖ™¬‰Îe¯;ç˜Ú*­ÕC˜ò®‚Òõ >Ke¹W GªØ‰{ò6 Ü“J§xl‰H{Ü»åL«IЗcÒ¤K]sêoù7Ý @07Ëð±ì }>®òë8¼Wëîê2Oq­ÉRħ Žx€|sÈ6\qfkıñe€shJ,a{\úêà’,×q›ŽºHòãx–b?ÅŒfegPÿ6¿ ²’–W»¾\Qð{ðhx]Þ‚Ëͣˣ%Hø„a‹/Ç፤Zôòéãol{@a;”õ÷ØyUQËþyŒ[î¢ìÏBûvü…lûà‚¾”¸Üû«‘±7ø»ÎªnËzªÑ“ç‡<àa« èS‘œ<G%š²Ø˜˜æUz2,לBa~ʼnÉð–›®7áÝJɺ§
¹îf—P¨/ØÖ_÷ˆ©Ë9ãuV:¯‡°Þ/ Eå5ò€Tiàè4ý+~yßž˜ÊB ’Ç$“VMÜI)¼¾´·œDqJ·gÙ}õTHv=U’ükx7s‰<µOŸ‹yŸ•a]'ùxb
TƒêÊ õ<’}_ʯ· êóÎèŠ99v†!U::™ZH‚ØÒ—Õҏý£JbûÞÅ>ïS ƒ J_v&†c§ùÛû÷E¥‹ãæÙï?ñÛ´)Ÿ{IýÜÐîÚWŒ<"AèÓ=Xe‹B8¨ÛþKÝg¡ocâj ÞZÆ[Svϐ¹ÑvC¼&_ÉCa—ýñ°Äÿ•c­–LÉm«l9Cßœ‘Gõz™Û!]›a3¦Ðës€o}Gا‡7˜óQX¹žƒZәꦸ$(ŸK›DÓ×훞PÓߍ}™>ðò±nöu’…X÷Æ®„ÇL U>k÷ß¡Áª<wIð LQç˜ÝÔyi×Iã”\²xÊŽ%MªƒwSµeó—’»-nÔ!=ïp€8áßü? læ™ oܬé¢[K9°:GÔ\iäáT’N2©1¥hÆë¡¸²vþîUãöGg0c†CgñaQª9"í¡°Þ‡üV+}và²ÜÈíó"5¤q^#§ý¢ûf°q«c¤^½·MjS¿°©ÛÍ›ÏÞ÷õÝæò¢¦Sޤ›í(ѐ7.ª“ímþhݳŒŸpÜ#Qׯ:íÛߝέñËeƒâ©géiYΘº6f;-
„£÷µ/@
£ó:ù±Mb€VˆC¼@
r©ò"j|Wñ$5~~3,”
[·T~f)ÊÉLÛw YöEª\‘œ–×ݘ0ž¤‚‘õ‘%ߤü»:Âí“ ƒn˜´ýwåÜi×ÊSØzQtkÖŸãÇž¿!4aãàbÔbåÏÔ©ŽYli¬PyÈjA,ÄÙ˜…+_ŽËµŽGC“[‡»ª´;E¥îYöÞÄîÔÑh¦¹X7î{~#DÚáùí¼eÔNÐ×3•N(KîÃ>©\k3/_QF?ÿÏèÃÌ-@¤/üÝ¥í15Å?gaxaº(Z¥iA"êsØEhצµ sEš‚SáŽ:m²¼cìmX|U=êaZút#ð*Xhnšmª|ªžä¶vÞÕÖ¶§\¸O–òtöžõ½jzuóYŸU›ÚÓ$&ù§bÕäV^ü7Å.é‘R%›ùC¹ˆ£±1n7FØ”â³-+s~D’ïm㜭|Š7gò“¥eøˆ­˜«>úê««è‚’òßx{‘éeÄç}ÆVµ™]¶3ÉKᰯ̚nó ® å)+E÷÷Æ\®µfÜà´Â›b¸E·‹”»Vÿáw»ôÝ
4ß/©×ÒcÔ9ÔÔne5 kž¹JÌ
}¥¼Å#^ü]£eÑÑe¥lZ@\œ#¤znÞõ—#bÄ,°uÕnG}*-tvËyÊN¤@¬›U}¦y‹Ýp­i­;Œædáò{ñÉøQ:jáĐ^çÊôrX/Å]eeÆ=RÙDlCW—Sœ~›U|f
ɪÍ.ñÆ}
ÿ¸ÿU‚ÊáûÌÙ‰8i_¥ykÑŸfÕˆX½&'çôˆÆðKŸº‹žî±œVXQlµdµë²kSÖ”E[¨º‡àT—ZÁ™©eY
hÃÊãs¥Y뻟:ÌR{[”~ßž,ÓLÏdñ;a
V¼6
›×;@–¾˜¯“辚ð@¼<©ó¨K3¨µ+"#t
¦Â9¹üM}Dƒ›às¼;Í·ÍÜ5¬is¦Êÿ«—® ’XM• HÔ’5~u5}Ó<ð“D­íúo0H$u¼,]ä>Û1ÍñÿàÛôiÚ$ꀷdµ—{‰
ÌÜF[Ïn”xìC|êÅ:jûÂpf<d¿Quqü+uËg/ÖÝ™œ$£G£u4—4…ìES%³Ojíkn×Lp@!ú4”—GÓ
ìA/Ø“Vxû}Å‘î܆€íu|4È“IoSôŸqxd]wÆý>—©€Û!#¦ðd)2U:ï–àÿf §ÝO´Æ ˆÅ̸µ°
Any ideas what is going wrong?
My guess is you extracted the iso instead of mounting the iso. You are supposed to mount the iso and run setup. from the screen with the 3 options you do the second/middle one first
Thank You Gramps were correct I down loaded Deamon Tools mounted the drive and built the USB. I can edit the WhiteLists so will carry on with the process.
Hello Gramps
OK I started again fresh. Ran setup and at first screen " Server Recovery Utilities" I selected second Option " Recreate My Storage" and built the USB ok. I edited WhitelistK and WhitelistS by adding the Bottom line below to both Files
WhiteListK.xml
<?xml version="1.0" encoding="utf-8"?> WDC WD2002FYPS-02W3B0 WDC WD2002FYPS-02W3B1 WDC WD2009FYPX-09AAMB0 WDC WD3009FYPX-09AAMB0
Hitachi HDS5C4040ALE630
HGST HDS5C4040ALE630
WDC WD2000F9YZ-09N20L0
WDC WD2000F9MZ-09NVPL0
WDC WD2000F9MZ-76NVPL0
WDC WD2000F9YZ-76N20L1
WDC WD2000F9YZ-09N20L1
serial=WD-WMC1P0D4VUFL model=WDC WD2000F9YZ-76N20L1
WDC WD3000F9YZ-09N20L0
WDC WD3000F9MZ-09NVPL0
WDC WD3000F9MZ-76NVPL0
WDC WD3000F9YZ-76N20L1
WDC WD3000F9YZ-09N20L1
WDC WD4000F9YZ-09N20L0
WDC WD4000F9MZ-09NVPL0
WDC WD4000F9MZ-76NVPL0
WDC WD4000F9YZ-76N20L1
WDC WD4000F9YZ-09N20L1
serial=WD-WCC5DCPKZA2H model=WDC WD4000F9YZ-76N20L1
WDC WD4000FYYZ-01UL1B0
WDC WD4000FRYZ-01F0DB0
CCF_000004.pdf (773.1 KB)
I then rebooted the DX4000 with Reset depressed and the files installed. The DX display then came back “Recreate Storage Failed”. I am not surprised by this as there are only 2 new drives in the box, so there was nothing to recreate.
Do I now press on with option 3 “Perform A Recovery” or do I have a problem to resolve?
Many Thanks Falcons 3
to be honest I have never done these edits but obviously you have something wrong.
There should be a log file on your thumb drive with hints.
You need to search this forum for more examples.
I think from what I have seen is the info listed above is inadequate
see here…more details than just model/SN
I checked the recovery.log file and the modified Whitelists seem to have been accepted as OK. Both disks have been detected inc Serial Numbers and marked as Pass-thru.
About half way down the file just under “Physical Disks Controlled by RAID S/W” there is a warning, “No Raid Volume Detected”.
Total Physical Disks = 2
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2020.02.07 19:31:50 - INFO - C:\wdrecovery\raidcfg64.exe /std
2020.02.07 19:31:50 - INFO - raidcfg64.exe /std Output:
******************** Driver Version Check DISABLED ********************
;Port,Model,SerialNumber,FirmwareVersion,Array,Status,Size,Free,Type
2,“WDC WD4003FRYZ-01F0D”,“V6JNUNPR”,“01.01H0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
3,“WDC WD4003FRYZ-01F0D”,“V1G9K2YB”,“01.01H0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
2020.02.07 19:31:50 - INFO - RaidCfg64 detected 2 drives
2020.02.07 19:31:50 - INFO - RaidCfg64 drive V1G9K2YB: port=3
2020.02.07 19:31:50 - INFO - RaidCfg64 drive V6JNUNPR: port=2
2020.02.07 19:31:50 - WARN - No RAID volume detected!
2020.02.07 19:31:50 - INFO - Checking RAID status (1): Volume Missing
2020.02.07 19:31:51 - INFO - Detected drive 0 serial=V6JNUNPR model=WDC WD4003FRYZ-01F0DB0 SATA=2 led=0
2020.02.07 19:31:51 - INFO - Security: SUPPORTED
2020.02.07 19:31:51 - INFO - Enabled: 0
2020.02.07 19:31:51 - INFO - Locked: 0
2020.02.07 19:31:51 - INFO - Frozen: 0
2020.02.07 19:31:51 - INFO - Master Password Id supported: 1
2020.02.07 19:31:51 - INFO - Master Password Id: 0xFFFE
2020.02.07 19:31:51 - INFO - Master Password Capability: None
2020.02.07 19:31:51 - INFO - Unlock Attempt Counter Exceeded: 0
2020.02.07 19:31:51 - INFO - Enhanced Erase: 0
2020.02.07 19:31:51 - INFO - Erase Time: Normal (raw 32970; 50400 sec)
2020.02.07 19:31:51 - INFO - Erase Time: Enhanced (raw 0; 50400 sec)
2020.02.07 19:31:51 - INFO - Detected drive 1 serial=V1G9K2YB model=WDC WD4003FRYZ-01F0DB0 SATA=3 led=1
2020.02.07 19:31:52 - INFO - C:\wdrecovery\raidcfg64.exe /i
2020.02.07 19:31:52 - INFO - raidcfg64.exe /i Output:
Version Tables:
Driver Version: 10.5.6.1001
OROM Version: 10.5.5.1050
App Version: 10.5.6.1002
Further on in the file the number of " Total Physical Disks" drops from 2 to 0 and no version number for Driver or OROM. In addition further down It deletes All Raid Volumes and then Re-creates Raid Volume, but is still unable to detect the Volume?
I am not sure how to interpret this or what to do to fix it?
Recovery.log attached.
recovery.txt (25.1 KB)
Look at this thread. I think the problem and I really have no clue why but it is the Passthrough. He linked the file that worked and it is says claimed. If you search for CLAIMED_DISK you will see a lot of hits
I have no clue what he did but seems like he may have had a bad bay?
There is some fellow on here that was the expert on whitelist. I think I would keep searching for whitelist. I will also look
