DX4000 recovery problems
Having some issues with a new to me DX4000.
I brought one of these units disk-less and i have installed 2x2TB WD Green drives and i have modified the whitelists on both USB drive’s so that these drives are accepted.
I have manually cleaned the 2 drive’s using disk part and then ran step 2 which has completed successfully.
Step 3 goes to recovery started and i can never get my PC to connect to the server when asked to press next. Anyone have any ideas?
Regards,
Greg
Log file:
2017.06.18 10:36:10 - DEBUG - Reading resource file ‘C:\wdrecovery\Locale\en_US.xml’
2017.06.18 10:36:10 - INFO - =========== Recovery app START ===========
2017.06.18 10:36:10 - INFO - Version: 1.7.6.21
2017.06.18 10:36:10 - INFO - Loading configuration
2017.06.18 10:36:10 - DEBUG - Reading recovery configuration ‘C:\wdrecovery\recoverycfg.xml’
2017.06.18 10:36:10 - ERROR - Unable to open file C:\wdrecovery\recoverycfg.xml
2017.06.18 10:36:10 - ERROR - Failed to load recovery configuration: 1
2017.06.18 10:36:11 - DEBUG - Parsing whitelist ‘C:\wdrecovery\whitelist.xml’
2017.06.18 10:36:11 - DEBUG - Element: ‘WhiteList’ line 5
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 7
2017.06.18 10:36:11 - DEBUG - End element ‘Model’
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 8
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 9
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 10
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 11
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 12
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 15
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 16
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 19
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 20
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 21
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 22
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 23
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 25
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 26
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 27
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 28
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 29
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 31
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 32
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 33
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 34
2017.06.18 10:36:11 - DEBUG - Element: ‘Model’ line 35
2017.06.18 10:36:11 - DEBUG - End element ‘WhiteList’
2017.06.18 10:36:11 - DEBUG - Reading enclosure map ‘C:\wdrecovery\encmap.xml’
2017.06.18 10:36:11 - DEBUG - Element: ‘EnclosureMap’ line 7
2017.06.18 10:36:11 - DEBUG - Element: ‘DriveMap’ line 9
2017.06.18 10:36:11 - DEBUG - Element: ‘DriveMapEntry’ line 10
2017.06.18 10:36:11 - DEBUG - Element: ‘DriveMapEntry’ line 11
2017.06.18 10:36:11 - DEBUG - Element: ‘DriveMapEntry’ line 12
2017.06.18 10:36:11 - DEBUG - Element: ‘DriveMapEntry’ line 13
2017.06.18 10:36:11 - DEBUG - End element ‘DriveMap’
2017.06.18 10:36:11 - DEBUG - Element: ‘FanThrottle’ line 16
2017.06.18 10:36:11 - DEBUG - Element: ‘FanSpeed’ line 17
2017.06.18 10:36:11 - DEBUG - Element: ‘FanSpeed’ line 18
2017.06.18 10:36:11 - DEBUG - Element: ‘FanSpeed’ line 19
2017.06.18 10:36:11 - DEBUG - Element: ‘FanSpeed’ line 20
2017.06.18 10:36:11 - DEBUG - Element: ‘FanSpeed’ line 21
2017.06.18 10:36:11 - DEBUG - End element ‘FanThrottle’
2017.06.18 10:36:11 - DEBUG - Element: ‘EthernetPorts’ line 24
2017.06.18 10:36:11 - DEBUG - Element: ‘Port’ line 25
2017.06.18 10:36:11 - DEBUG - Element: ‘Port’ line 26
2017.06.18 10:36:11 - DEBUG - End element ‘EthernetPorts’
2017.06.18 10:36:11 - DEBUG - Element: ‘TemperatureStatus’ line 29
2017.06.18 10:36:11 - DEBUG - Element: ‘CPUTemp’ line 31
2017.06.18 10:36:11 - DEBUG - Element: ‘DriveTemp’ line 32
2017.06.18 10:36:11 - DEBUG - End element ‘TemperatureStatus’
2017.06.18 10:36:11 - DEBUG - Element: ‘FanSetting’ line 38
2017.06.18 10:36:11 - DEBUG - Element: ‘FanPWM’ line 39
2017.06.18 10:36:11 - DEBUG - Element: ‘FanPWM’ line 40
2017.06.18 10:36:11 - DEBUG - Element: ‘FanPWM’ line 41
2017.06.18 10:36:11 - DEBUG - End element ‘FanSetting’
2017.06.18 10:36:11 - DEBUG - Element: ‘Polling’ line 44
2017.06.18 10:36:11 - DEBUG - Element: ‘PowerSupply’ line 45
2017.06.18 10:36:11 - DEBUG - End element ‘Polling’
2017.06.18 10:36:11 - DEBUG - Element: ‘PowerSupplyMap’ line 48
2017.06.18 10:36:11 - DEBUG - Element: ‘PowerSupply’ line 49
2017.06.18 10:36:11 - DEBUG - Element: ‘PowerSupply’ line 50
2017.06.18 10:36:11 - DEBUG - End element ‘PowerSupplyMap’
2017.06.18 10:36:11 - DEBUG - End element ‘EnclosureMap’
2017.06.18 10:36:15 - INFO - In MS Recovery Mode
2017.06.18 10:36:15 - INFO - Detected drive 0 serial=WD-WMC302126938 model=WDC WD20EURS-63SPKY0 SATA=2 led=0
2017.06.18 10:36:15 - INFO - Security: SUPPORTED
2017.06.18 10:36:15 - INFO - Enabled: 0
2017.06.18 10:36:15 - INFO - Locked: 0
2017.06.18 10:36:15 - INFO - Frozen: 0
2017.06.18 10:36:15 - INFO - Master Password Id supported: 1
2017.06.18 10:36:15 - INFO - Master Password Id: 0xFFFE
2017.06.18 10:36:15 - INFO - Master Password Capability: None
2017.06.18 10:36:15 - INFO - Unlock Attempt Counter Exceeded: 0
2017.06.18 10:36:15 - INFO - Enhanced Erase: 1
2017.06.18 10:36:15 - INFO - Erase Time: Normal (raw 143; 17160 sec)
2017.06.18 10:36:15 - INFO - Erase Time: Enhanced (raw 143; 17160 sec)
2017.06.18 10:36:15 - INFO - Detected drive 1 serial=WD-WCC4M1898677 model=WDC WD20EURX-63T0FY0 SATA=3 led=1
2017.06.18 10:36:15 - INFO - Erase Time: Normal (raw 144; 17280 sec)
2017.06.18 10:36:15 - INFO - Erase Time: Enhanced (raw 144; 17280 sec)
2017.06.18 10:36:15 - INFO - C:\wdrecovery\raidcfg64.exe /i
2017.06.18 10:36:15 - INFO - raidcfg64.exe /i Output:
Version Tables:
Driver Version: 10.5.6.1001
OROM Version: 10.5.5.1050
App Version: 10.5.6.1002
******************** Driver Version Check DISABLED ********************
Physical Disks Controlled by RAID S/W
Disk 01 / 02
Disk: WDC WD20EURS-63SPKY0 SerialNo:WD-WMC302126938
Description:EURS-63SPKY0 Summary:Array Member
Rev:80.00A8 Summary:Array Member
FreeBlks:0x150F TotalBlks:0xE8E088B0
BusId:0x00000002 TargetId:0x00000000 LUN:0x00000000 Array:0x00
Partitions:02 CheckBox:0x00000000 CfgStatus:(00) Ok
Action:00 SMARTEvt:0x00000001 WriteCache:ON
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
DISK_SMART_EVENT_SUPPORTED
Disk 02 / 02
Disk: WDC WD20EURX-63T0FY0 SerialNo:WD-WCC4M1898677
Description:EURX-63T0FY0 Summary:Array Member
BusId:0x00000003 TargetId:0x00000000 LUN:0x00000000 Array:0x00
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Total Physical Disks = 2
RAID Volumes
Volume 01 / 01
SerialNo:Volume0 Summary:Normal
RaidLevel: 1 MemberDisks:02 Domains/Mirrors:02 TargetId:0x01
SizeInMB:1907726 BytesPerBlock:0x00000200 StripSize: 64KB
Action:00 Array:00 MapState:00 MigrState:00 MigrType:00 CfgStatus:0x00000000
Total Volumes = 1
RAID Arrays
Array 01 / 01
NumDisks:02 RAIDDevs:01 TotalMB:3815457 FreeMB:5
State:00 CheckBox:0x00000000
Total Arrays = 1
2017.06.18 10:36:15 - INFO - C:\wdrecovery\raidcfg64.exe /std
2017.06.18 10:36:15 - INFO - raidcfg64.exe /std Output:
;Port,Model,SerialNumber,FirmwareVersion,Array,Status,Size,Free,Type
2,“WDC WD20EURS-63SPKY0”,“WD-WMC302126938”,“80.00A8”,0,“Normal”,3907029168,5391,“ArrayMember”
3,“WDC WD20EURX-63T0FY0”,“WD-WCC4M1898677”,“80.00A8”,0,“Normal”,3907029168,5391,“ArrayMember”
2017.06.18 10:36:15 - INFO - RaidCfg64 detected 2 drives
2017.06.18 10:36:15 - INFO - RaidCfg64 drive WD-WCC4M1898677: port=3
2017.06.18 10:36:15 - INFO - RaidCfg64 drive WD-WMC302126938: port=2
2017.06.18 10:36:15 - INFO - Matched drive 1 serial WD-WCC4M1898677 model WDC WD20EURX-63T0FY0 with white list entry Enterprise Storage 2 TB
2017.06.18 10:36:15 - INFO - Matched drive 0 serial WD-WMC302126938 model WDC WD20EURS-63SPKY0 with white list entry Enterprise Storage 2 TB
2017.06.18 10:36:15 - INFO - Checking RAID status (1): Volume Good
2017.06.18 10:36:16 - INFO - Detected drive 0 serial=WD-WMC302126938 model=WDC WD20EURS-63SPKY0 SATA=2 led=0
2017.06.18 10:36:16 - INFO - Security: SUPPORTED
2017.06.18 10:36:16 - INFO - Enabled: 0
2017.06.18 10:36:16 - INFO - Locked: 0
2017.06.18 10:36:16 - INFO - Frozen: 0
2017.06.18 10:36:16 - INFO - Master Password Id supported: 1
2017.06.18 10:36:16 - INFO - Master Password Id: 0xFFFE
2017.06.18 10:36:16 - INFO - Master Password Capability: None
2017.06.18 10:36:16 - INFO - Unlock Attempt Counter Exceeded: 0
2017.06.18 10:36:16 - INFO - Enhanced Erase: 1
2017.06.18 10:36:16 - INFO - Erase Time: Normal (raw 143; 17160 sec)
2017.06.18 10:36:16 - INFO - Erase Time: Enhanced (raw 143; 17160 sec)
2017.06.18 10:36:16 - INFO - Detected drive 1 serial=WD-WCC4M1898677 model=WDC WD20EURX-63T0FY0 SATA=3 led=1
2017.06.18 10:36:16 - INFO - Erase Time: Normal (raw 144; 17280 sec)
2017.06.18 10:36:16 - INFO - Erase Time: Enhanced (raw 144; 17280 sec)
2017.06.18 10:36:16 - INFO - C:\wdrecovery\raidcfg64.exe /i
2017.06.18 10:36:16 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Volume 01 / 01
Total Volumes = 1
RAID Arrays
Array 01 / 01
Total Arrays = 1
2017.06.18 10:36:16 - INFO - C:\wdrecovery\raidcfg64.exe /std
2017.06.18 10:36:16 - INFO - raidcfg64.exe /std Output:
2017.06.18 10:36:16 - INFO - RaidCfg64 detected 2 drives
2017.06.18 10:36:16 - INFO - RaidCfg64 drive WD-WCC4M1898677: port=3
2017.06.18 10:36:16 - INFO - RaidCfg64 drive WD-WMC302126938: port=2
2017.06.18 10:36:16 - INFO - Matched drive 1 serial WD-WCC4M1898677 model WDC WD20EURX-63T0FY0 with white list entry Enterprise Storage 2 TB
2017.06.18 10:36:16 - INFO - Matched drive 0 serial WD-WMC302126938 model WDC WD20EURS-63SPKY0 with white list entry Enterprise Storage 2 TB
2017.06.18 10:36:16 - INFO - Checking RAID status (2): Volume Good
2017.06.18 10:36:33 - ERROR - Failed to get disk data
2017.06.18 10:36:33 - INFO - cscript.exe //NoLogo C:\wdrecovery\partutil.vbs -FindData
2017.06.18 10:36:38 - INFO - partutil.vbs output
Number of disks: 2
Disk Index: 0
Scanned disk 0
Microsoft DiskPart version 6.1.7600
Copyright (C) 1999-2008 Microsoft Corporation.
On computer: MININT-B1DHK4A
Disk 0 is now the selected disk.
There are no partitions on this disk to show.
No EFI partition found!
Disk does not contain proper partitions
2017.06.18 10:36:38 - ERROR - Failed to run partutil.vbs: exit code = 2
2017.06.18 10:36:38 - WARN - Did not create Data Partition flag file on volume ‘’
2017.06.18 10:36:38 - INFO - X:\windows\system32\ServerRecovery.exe
2017.06.18 10:36:38 - INFO - Started MS server recovery
Do’t know why i didn’t try this earlier but i have managed to get this going now!!
Spun up a Windows 7 VM and run the tool from there and it found the server straight away and is currently formatting the hard drives. So it looks like it doesn’t like my Win10 machine.
strange…3rd party AV or Firewall?
