hello
i hope somebody can help me.
i used the hard disk in the past no prob.
now the wireless light doesn’t blink and i can not access it.
do you know why?
thanks a lot
If you plug the drive into the usb port does it show up then?
always the same…worst it tells me that the hard disk is not readable…when it was readable before!
