WD TV Live Hub Media Centre - No Remote
I have a Wd TV Live Hub Media Centre. We use as a hard drive to watch movies through the TV. It is not connected to the internet. We have lost the remote. Is there an app I can download to be able to control the device?
There used to be, it was called “WD Remote” but I don’t think it’s available on the app stores anymore.
IIRC, there’s a web-based applet for the remote in the web dashboard of the hub
It’s here isn’t it ?
https://play.google.com/store/apps/details?id=com.wdc.wdremote&hl=en_AU
WD Remote app is still on the Google Play i think (link above)
You can plug in and use a USB Keyboard (or a Wireless one with a USB dongle) to control the WDTV Live Hub if you’re in a pinch
And don’t forget, WD remotes (or clones thereof) are available for a few bucks from eBay or Amazon, etc.
If you PM me and are willing to pay for the postage i have a spare if this helps
this topic is 2 Years old … i think the OP has moved on.
yes so it seems
i have been reading here for years but never joined
