I have just got a WD TV Live media player, about 4 days ago, and been trying to connect it to a Netgear Readynas.
The system is set up with a Virgin Media super Hub connected to a Netgear GS105 switch with one of the feeds going to a Belkin wireless router which is located in the room where my WD TV is located. The nas is located next to the GS105 and hard wired to it.
I have tried to connect to the nas thro the WD TV using the wired connection but with no success, so tonight I tried using it wirelessly and it worked.
The question is why will the media player work wirelessly but not wired?
I have tried the WD help thro email but the answer I got:-
Well, you did not answer my questions, and your questions are just not precise enough to answer, for example, what do you mean by “it works” or it “doesn’t work”. And, what wires are connected to what, USB, ethernet?.
I don’t understand why the media player works when connected wirelessly but not when it is hard wired.
I would say there are three likely reasons: (1) your SMP is defective, (2) some of your network gear is defective, or (3) your network is improperly setup for the purposes you are trying to use it for.
As already noted, you haven’t provided enough information to say much more or to help you devise a plan to debug.
I am having the same problem. I made a post last week but never got any answers. I tried inputting all the same numbers as the wireless settings but still doesn’t work. Hope someone can figure this out. I am not using any network shares or anything. Just connecting to the WMP on my computer. It did work at one point but that has been a while back.
Well that is not a good idea if your wireless is still enabled then you can create an address conflict. How many devices do you have? 5? 10? If you dont know what the IPs are for all you devices the just open a command prompt in windows and use “ping” to find an available IP. While you have a command prompt you might also do an “ipconfig /all” make sure of the gateway and DNS server IPs.
This is my setup i too have a netgear router dgn2200 on win 7 i use wired config that is ethernet attached to back of wdtv smp and connected to the router.and another ethernet cord mines 5 metres long from router to ethernet port on my laptop.i check the network folder in my windows tab on my laptop i check to see if wdtv is in the folder under computer and media devices there are two references to my media player in the network folder, if you cannot see the devices in that folder then you are not getting any network connection from the wdtv smp.
Try this go to network settings in wdtv smp then 1st option then wired then automatic then when all is done check network folder and see if the wdtv has been recognised this setup works for me anyways hope this helps
