Hello. My wd my passport is not working. i got it on Christmas unopened and it stopped working january 22 this year. i have tried the freezer trick, and just waiting. i think the data reader is stuck and if you can give me a tutorial how to put it in the right place that would be helpful
thanks in advance
if you help me
Have you tried using the unit on a different PC or using a different USB cable?
Yes, it still doesn’t work
When I go into the we drive utilities it shows no smart status and it is 0 bytes please help, it started happening in January and I got it in December 2015. I can’t afford another one and I don’t care about the data on it.
where you able to access your external hd?
