WD home duo MacBook connect problem
After routine upgrade my MacBook Pro to MOJAVE, My 8GB WD home duo stop work through WD discovery for mac. I think it is stop working with Mojave and need software update which is not available yet.
What can I do, I bought it for my mackBook pro?
Hi drmmz68,
You may check after updating the firmware to use My Cloud on macOS 10.14 (Mojave). You can have a look on below article in this concern.
https://support.wdc.com/knowledgebase/answer.aspx?ID=25994&lang=en
