Wd easy store usb not recognised by smart tv
SO BOUGHT A NEW 4T WD EASYSTORE TRANSFERED ALL MY MOVIES FROM MY 1 TB WD SEAGATE OR PASSPORT HD WENT TO HOOK UP TO MY SAMSUNG SMART TV AND NOTHING COMES ON BUT APPARENTLY ISNT RECOGNISABLE ALL MY OTHER HD WORK FINE LOOKED IT DISK MANAGMENT SAYS IT FORMATTED TO NTHS OR SOMETHING LIKE THAT NEED HELP PLEASE :frowning_face:
That’s more a question for Samsung than WD.
You need to check your TV’s documentation to find out if it supports a drive of that size, what format it requires, and what partition type it requires.
I just know I have a 1t or 2t passport ultra and it works fine Samsung shows it supports the file type that is formatted on this drive if correct but I’ll double check
