Second one got it stuck in intermitent white light. Took 30 minutes for it to finally boot while I was panicking over it.
After that, UI or shares were not responding. Using SSH I find that **bleep** wdmcserver is using 98% CPU so I shut it down. Now I’m able to access shares. But still unable to use the browser UI: Whenever you try access it, you end up with error 500 (“HTTP 500 Internal Server Error”).
Oh, and subsequent reboots will also take a huge amount of time.
So… System Restore pressing 40 seconds the back reset button?
Don’t go there just yet!
I tried this and I am having a very hard time struggling back to a usable state. Every single user action takes several minutes to complete, and I have not yet succeeded in logging back in to the drive. I am currently stuck re-creating my WDMyCloud.com login. It did not let me use my existing ID and is now just sitting there saying “Updating…”.
Seems that there is some kind of issue with the web app that Apache should be running. But I don’t have any idea on how to do some kind of system restore without having access to the dashboard of even if that might help.
I still have access to SSH and shares, so I’m still good… But I need to fix this.
I’m able to access Twonky and my shares but not the main UI dashboard. I’m unable to make a connection on SSH, as I hadn’t turned it on. Is there a way to enable SSH other than through the dashboard?
No that I know of… Try to get in touch with support, maybe they have some way to “force” some automatic update.
I have same problems with extremely unresponsive Dashboard and all user interaction taking for ever. Can you explain this SSH process in a bit more detail please? I am assuming I will be able to turn it on at some point even if I have to wait for an hour!! Please help!
Is there an easy way to downgrade the firmware. Can access ssh fine but do not want v4 when it’s buggy and won’t allow the use of transmission anymore.
Doesn’t sound good, read through the Guide Transm** ission2.82** thread and you will find instructions on down grading the firmware if you so choose or re-apply the current V4 firmware in another recent thread, but both require ssh. Hopefully you can get ssh or the dashboard running.
Tried the steps in the guide and it didn’t work for me luckily I enabled ssh beforehand though. Will have to keep trying.
Which part didn’t work? I had to manually download the 3.4 firmware from my web browser and then unzip it into the nas public folder as the wget command was killed by the abominbal V4 firmware (selinux?). Once the unzipped firmware was in place in the nas public folder/fileshare and I edited the updateFirmwareFromFile.sh script and commented/hashed out the downgrade prevention and then ran the updateFirmwareFromFile.sh script on the firmware.
I applied the update again using Manual Update from the Dashboard. Gave it one night to sleep and catch up with content scanning. Everything seems to be working as earlier for me now. All user interactions are as it used to be (it was never superfast) and my internet connection seems to be holding up so far. I had a few conflicting port forwarding set up in my router and I removed them. So, fingers crossed for now. I am not going to be downgrading.
