Greetings all, season or otherwise.
I find myself in a bit of fix here as I’m trying to link together my My Cloud to a set of USB 3.0 SeaGate external HDDs and I’ve hit an impass. I’ve read online about this and it should work fine as long as you’re linking them through a USB 3.0 hub with it’s own external power. And it did work, but was kind of unstable. Well all of a sudden it’s stopped working at all together. And even worse now I can’t get ANY USB devices to link into my My Cloud. Not the drives indivitually, not a 2.5" USB HDD drive in an enclosure, nor even a standard USB thumb drive. Doesn’t even show up in the UI when I connect something into it.
I’ve tried doing my best reading forums and posts anywhere I can find them. I’ve run many self tests and checks to little affect. I’ve even go so far as to do a ‘System Only’ factory reset on the device. Yet no dice…
Anyone have anything suggestions?
