Solid white light from initializing
Hi, sorry I saw a lot of thread died half way with regards to the solid white light from power on.
What are the possible solutions other than losing all the data?
Hi @Wjlim83,
Please refer to the following information to check if they can help you solve the issue:
-My Cloud Home Online User Guide and Solutions:
-My Cloud Home Front LED Blinking Behavior:
Hi I have went through the guide and it doesn’t help with the current situation.
I appreciate that you have performed the troubleshooting steps.
