I’m copying files from my computer running windows vista on a wireless network to the Hub and I am getting transfer rates that max out at 800kb/s. Even then it takes a few minutes before it even gets up to that speed. The hub is connected to a network hub and then to my wireless router.
Any ideas why the speed is so slow? I read through some of the posts here and found some people getting speeds of 5MB/s.
Could it be that its running through that other network hub?
8 to 10 Mb/s? I only get 12 to 17 Mb/s on USB syncing; and on my network wireless/wired mximum 4 Mb/s. Average is 2 to 3Mb/s.
But this is when I sync. There are some limitations in the software with wich you sync too. I sync actively from my computer to the WDTV with my own sync software. And I think that also limits the speed.
So if you get 800Kb/s you should try to drop a file on your disc without syncing software and see how fast it copies. If it is still 800Kb/s it is too slow and it is probably your network. Check cables, and check the wireless speeds if you use it.
right ok, so i still should be getting at least a few MB/s.
I’m not using any sync software, as of yet. This is just when I simply copy and paste a file through windows explorer. WD Hub is wired in, so i can’t see that reducing speed, unless the inline hub is affecting it. And my laptop has 80-90% full bars on wireless and I can get great download speeds on torrents and web browsing. For example I get up to 1.3MB/s on torrents. Should be able to get at least that internally!
My setup is wireless at both the hub and pc and I get 4-5 megs per second on a copy to the hub from my pc. That is absolutely as fast as I could achieve after much tinkering. My wireless devices usuallly show a 300Mbps connection speed at both the sending and receiving devices. You’re probably being limited by your wireless connection and you may be getting some interference. Have you tried a different channel or channel width. That’s what finally worked for me.
Also, If you ever need to go wireless at the hub, I finally resorted to using a wireless bridge. It proved to be more stable than a wireless usb adapter and it frees up one of your usb ports.
I tried using a few differnet channels and got slightly faster speeds. Only slightly though, 900kb/s and then drops somewhat lower again. I looked all through my router settings and couldn’t find any option for changing the channel width.
Thanks for the help!
*> Phil,
This is surely your wireless connection. I use a Devolo 200 AV mini homeplug and it gives me up to 4Mb/s. However I send it wireless to my modem from there it goes through the homeplugs.
Hey but how do you get such a fast connection. I mean to me your 8Mb/s is some superspeed! You work wired? I use a homeplug from my modem to the WDTV. This should enable around 35Mb/s I tested it with my computer while downloading through the homeplug from internet.
From my macbook wireless to the modem gives my much higher speeds. Still after testing the WDTV it gives no more than a top of 4Mb/s from computer through the modem to the homeplug.
TonyPh12345 wrote:
I think it’d be helpful to not use abbreviations. I get 8 megaBYTES per second quite easily. Wired or wireless.
I was just called out iby a user about this. Hee hee! :) And I have no problems backing up my statements.
Here’s a screen scrape; I was just copying a file off the USB Stick in my WDTVLIVE running 1.03.49 via Wireless Network (WUSB600N to Linksys E3000) to my Win7 PC which is wired.
The average was around 9.5 but I got bursts up to 11 Megabytes per second during this copy (it’s hard to react fas enough on those Screen-Grab keys t to get those scrapes though!)
Acchh! Just realized we’re talking about the HUB.
Here’s a copy TO the Hub via WIRED network, with slightly better performance…
Well… for the record, I am the user TonyP is referring to. Wireless at 9.2 is amazing!
Here is my sustained speed from PC to Live Plus on my wired MoCA network. I’m amazed that it is almost the same as your wireless! I get slightly lower speed from PC to HUB…about 8.5MB/sec. Im assuming the speed is lower to HUB because of the chipset it uses but that is just a quess…
Just putting some math to this can help ya’ll understand.
The Live / Live+ have the same Ethernet interface. They’re actually the same chipset; the Plus just includes hardware DRM but the rest is pretty much the same.
It’s a 100 megabit per second interface.
When Windows 7 shows the throughput, it’s REAL throughput; as in how many bytes per second of the FILE are being moved.
A touch over 11 megabytes per second is getting close the MAXIMUM POSSIBLE; that would equate to 88 megabits per second. Once you tack on the overhead for the SAMBA, TCP, IP, and Ethernet protocol layers, you’re getting right up to the maximum of 100 megabits per second.
The Hub has the same chipset as the Live+, but it uses an EXTERNAL Ethernet interface via the Chipset’s built-in PCI bus interface. So, if you actually have a Gigabit Ethernet network end-to-end, you can go over that limit of 100 megabits per second, but not much, because the Sigma Processor just isn’t made to move a lot of data at high speeds.
And if you’re using a clean Wireless N netowrk, it’s going to hit the Processor’s limit far sooner than it’d hit the theoretical 300 megabit per second N limitation…
I took a look at that page, the solution being to using a coxial network? Id be satisified with just getting a few MB/s vs 800kb/s. Also I have wired ethernet running through most of the house, so that isn’t really a problem.
I tried transferring files with my laptop plugged in direct to the router. I get transfer rates of 1.07 MB/s. So its a bit faster, but I feel like it should still be possible to get it going a bit more.
It could also be the case in my situation. I mean that SOME parts only support 10Mbits. I reach up to 2 Mbytes/s average. That is around 12Mbits which is close to 10Mbits. I can reach around 40Mbits on my homplugs even though they are sold as 200MBits/s. But wireless I can go higher.
What you suggest us to do:
Go wireless ( not advised by WD )
buy certified 100 of higher ethernet cables and switches etc.
In my present set uo I can beam HD1080p movies from internet to my WDTV. But I get problems if I am backing up and want to listen to internet radio at the same time.
Yesterday I finished transferring the episode 1 of season 1 of my favorite TV program.
The transfer is a little slow …
Today airs episode 10 of season 6.
The transfer is a bit slow??
In these times when a file is in sizes 6 or 7 gb, a transfer rate of 12 MB / S maxima is a PLAIN SHAME !
