Wireless connection slower than it should be
Hi everyone.
I have a WD TV Live plus 1TB with an Asus N pen connected to my Router that is N too. But i noticed that the speed I copy movies from my desktop to my WD TV is too slow. With a movie around 15Gb it takes about 3 hours :S is it normal?
Do I need to change something in the WD TV or in my router to make it a litle faster?
Hi there, can you please post more details related to the speed you get, the overall network configuration and if you get the same speeds with a wired connection? o.o
If my math is right, you’re saying you get an average of
about 12 megabits per second.
Yeah, that’s pretty bad.
I agree with PM.  Try a wired connection (just walk your WD and drive over to your network switch and plug it in there… no need to have it connected to a TV) and see if it’s better.
