Sentinel dx4000 recovery recreate problems (solved)
A bit of a story, but here goes.
On Friday the server crashed, tried rebooting but no luck, then bad storage flashed up.
So messed about with the server to try and track the origin of the fault. Put disks in 1 by1 and followed everyone’s advice from here.
So after spending a fair few hours getting nowhere, i decided to do a restore and hope i wouldn’t lose the data.
And as i feared it wouldn’t work, kept trying but kept failing with the error 0xd9 error
so again on following the advice of gramps on a similar topic, I did the recreate drives option first and then tried the restore option.
Success(sort of)
I was then able to reinstall the server software, but the DX wouldn’t recognize there were 2 HDDS inserted.
And then after a while it would flash up on LCD bad storage and then tried repairing, this took about 24hrs.
The repair finished, then it started to migrate and this took well over 24hrs to complete.
Once it completed, it flashed up that storage was bad, and I then couldn’t access the server.
I then tried to do a restore on it again to try and get it going as even though it was saying bad storage it wasn’t indicating if it was a specific drive was the problem
Now I still had the recovery image I had used on Saturday, went through all the same steps as before, but now I can’t even manage to recreate the storage option to work.
I’ve spent roughly about 10 hrs on it today and tried almost every bit of advice I’ve read here
I’ve changed drives around put in 2 and 4 knowing the other 2 wouldn’t be recognized till I installed the drive enabler software again, nothing works.
I’ve checked the the recreate file on the USB drive and it says that it cannot create raid.
this is the end of the recovery file
******************** Driver Version Check DISABLED ********************
;Port,Model,SerialNumber,FirmwareVersion,Array,Status,Size,Free,Type
2,“WDC WD4000F9YZ-09N20”,“WD-WCC5D7T66KVV”,“01.01A0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
3,“WDC WD4000F9YZ-09N20”,“WD-WCC1F0457392”,“01.01A0”,-1,“Normal”,7814037168,7814037168,“ArrayMember”
2022.04.20 15:17:16 - INFO - RaidCfg64 detected 2 drives
2022.04.20 15:17:16 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=3
2022.04.20 15:17:16 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=2
2022.04.20 15:17:16 - WARN - No RAID volume detected!
2022.04.20 15:17:16 - INFO - Checking RAID status (2): Volume Missing
2022.04.20 15:17:17 - WARN - RAID volume status is bad or volume is missing, need to re-create the RAID volume: Volume Missing
2022.04.20 15:17:18 - INFO - Deleting all RAID volumes
2022.04.20 15:17:22 - INFO - Re-creating RAID volume
2022.04.20 15:17:22 - INFO - C:\wdrecovery\raidcfg64.exe /Y /c:Volume0 /l:1 /ds:3 2
2022.04.20 15:17:22 - INFO - raidcfg64.exe output
Disk Selection Failed: Invalid port selection.
Only non-RAID disks or disks of a single volume can be selected.
2022.04.20 15:17:22 - ERROR - Failed to create RAID: exit code = 1
2022.04.20 15:17:22 - ERROR - Failed to create RAID volume: RaidCfg Util Error
2022.04.20 15:17:23 - INFO - =========== Recovery app END (4) ===========
i dont know why its now doing this as ive done exactly what i did on saturday using the same thumbdrive and iso image, ive even used one that gramps has linked but nothing seems to be helping.
ive ran it through diskpart and followed all the advice on what to do with the drives and nothing changes.
any sort of help would be appreciated, as im absolutely at a loss as to what’s changed between what worked on saturday to not working today.
thanks
You know your data is gone correct?
Do diskpart clean again on the 2 drives
yeah i know its went, ive made peace with it.
in process of cleaning drives just as i type this
update
done clean with diskpart on both discs reinserted ran recreate, gets to cleaning then appears to be about to go to next stage and then fails
log files
this is the recovery log file
Wed 04/20/2022 15:46:41.41 Using platform STARGATE configuration
2022.04.20 15:46:44 - DEBUG - Reading resource file ‘C:\wdrecovery\Locale\en_US.xml’
2022.04.20 15:46:44 - INFO - =========== Recovery app START ===========
2022.04.20 15:46:44 - INFO - Version: 1.7.6.21
2022.04.20 15:46:44 - INFO - Loading configuration
2022.04.20 15:46:44 - DEBUG - Reading recovery configuration ‘C:\wdrecovery\recoverycfg.xml’
2022.04.20 15:46:44 - ERROR - Unable to open file C:\wdrecovery\recoverycfg.xml
2022.04.20 15:46:44 - ERROR - Failed to load recovery configuration: 1
2022.04.20 15:46:46 - DEBUG - Parsing whitelist ‘C:\wdrecovery\whitelist.xml’
2022.04.20 15:46:46 - DEBUG - Element: ‘WhiteList’ line 5
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 7
2022.04.20 15:46:46 - DEBUG - End element ‘Model’
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 8
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 9
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 10
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 13
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 14
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 17
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 18
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 19
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 20
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 21
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 23
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 24
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 25
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 26
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 27
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 29
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 30
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 31
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 32
2022.04.20 15:46:46 - DEBUG - Element: ‘Model’ line 33
2022.04.20 15:46:46 - DEBUG - End element ‘WhiteList’
2022.04.20 15:46:46 - DEBUG - Reading enclosure map ‘C:\wdrecovery\encmap.xml’
2022.04.20 15:46:46 - DEBUG - Element: ‘EnclosureMap’ line 7
2022.04.20 15:46:46 - DEBUG - Element: ‘DriveMap’ line 9
2022.04.20 15:46:46 - DEBUG - Element: ‘DriveMapEntry’ line 10
2022.04.20 15:46:46 - DEBUG - Element: ‘DriveMapEntry’ line 11
2022.04.20 15:46:46 - DEBUG - Element: ‘DriveMapEntry’ line 12
2022.04.20 15:46:46 - DEBUG - Element: ‘DriveMapEntry’ line 13
2022.04.20 15:46:46 - DEBUG - End element ‘DriveMap’
2022.04.20 15:46:46 - DEBUG - Element: ‘FanThrottle’ line 16
2022.04.20 15:46:46 - DEBUG - Element: ‘FanSpeed’ line 17
2022.04.20 15:46:46 - DEBUG - Element: ‘FanSpeed’ line 18
2022.04.20 15:46:46 - DEBUG - Element: ‘FanSpeed’ line 19
2022.04.20 15:46:46 - DEBUG - Element: ‘FanSpeed’ line 20
2022.04.20 15:46:46 - DEBUG - Element: ‘FanSpeed’ line 21
2022.04.20 15:46:46 - DEBUG - End element ‘FanThrottle’
2022.04.20 15:46:46 - DEBUG - Element: ‘EthernetPorts’ line 24
2022.04.20 15:46:46 - DEBUG - Element: ‘Port’ line 25
2022.04.20 15:46:46 - DEBUG - Element: ‘Port’ line 26
2022.04.20 15:46:46 - DEBUG - End element ‘EthernetPorts’
2022.04.20 15:46:46 - DEBUG - Element: ‘TemperatureStatus’ line 29
2022.04.20 15:46:46 - DEBUG - Element: ‘CPUTemp’ line 31
2022.04.20 15:46:46 - DEBUG - Element: ‘DriveTemp’ line 32
2022.04.20 15:46:46 - DEBUG - End element ‘TemperatureStatus’
2022.04.20 15:46:46 - DEBUG - Element: ‘FanSetting’ line 38
2022.04.20 15:46:46 - DEBUG - Element: ‘FanPWM’ line 39
2022.04.20 15:46:46 - DEBUG - Element: ‘FanPWM’ line 40
2022.04.20 15:46:46 - DEBUG - Element: ‘FanPWM’ line 41
2022.04.20 15:46:46 - DEBUG - End element ‘FanSetting’
2022.04.20 15:46:46 - DEBUG - Element: ‘Polling’ line 44
2022.04.20 15:46:46 - DEBUG - Element: ‘PowerSupply’ line 45
2022.04.20 15:46:46 - DEBUG - End element ‘Polling’
2022.04.20 15:46:46 - DEBUG - Element: ‘PowerSupplyMap’ line 48
2022.04.20 15:46:46 - DEBUG - Element: ‘PowerSupply’ line 49
2022.04.20 15:46:46 - DEBUG - Element: ‘PowerSupply’ line 50
2022.04.20 15:46:46 - DEBUG - End element ‘PowerSupplyMap’
2022.04.20 15:46:46 - DEBUG - End element ‘EnclosureMap’
2022.04.20 15:46:50 - INFO - In MS Recovery Mode
2022.04.20 15:46:50 - INFO - Detected drive 0 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.20 15:46:50 - INFO - Security: SUPPORTED
2022.04.20 15:46:50 - INFO - Enabled: 0
2022.04.20 15:46:50 - INFO - Locked: 0
2022.04.20 15:46:50 - INFO - Frozen: 0
2022.04.20 15:46:50 - INFO - Master Password Id supported: 1
2022.04.20 15:46:50 - INFO - Master Password Id: 0xFFFE
2022.04.20 15:46:50 - INFO - Master Password Capability: None
2022.04.20 15:46:50 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.20 15:46:50 - INFO - Enhanced Erase: 1
2022.04.20 15:46:50 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.20 15:46:50 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.20 15:46:50 - INFO - Detected drive 1 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.20 15:46:50 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.20 15:46:50 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.20 15:46:50 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.20 15:46:50 - INFO - raidcfg64.exe /i Output:
Version Tables:
Driver Version: 10.5.6.1001
OROM Version: 10.5.5.1050
App Version: 10.5.6.1002
Physical Disks Controlled by RAID S/W
Disk 01 / 02
Disk: WDC WD4000F9YZ-09N20 SerialNo:WD-00000000000V
Description:00F9YZ-09N20 Summary:Pass-thru
Rev:01.01A0 Summary:Pass-thru
FreeBlks:0x1D1C0BEB0 TotalBlks:0x1D1C0BEB0
BusId:0x00000002 TargetId:0x00000000 LUN:0x00000000 Array:0xFF
Partitions:01 CheckBox:0x00000000 CfgStatus:(00) Ok
Action:00 SMARTEvt:0x00000001 WriteCache:ON
State:(0x40000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
DISK_SMART_EVENT_SUPPORTED
Disk 02 / 02
Disk: WDC WD4000F9YZ-09N20 SerialNo:WD-00000000002
Description:00F9YZ-09N20 Summary:None
Rev:01.01A0 Summary:None
BusId:0x00000003 TargetId:0x00000000 LUN:0x00000000 Array:0xFF
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Total Physical Disks = 2
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.20 15:46:50 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.20 15:46:50 - INFO - raidcfg64.exe /std Output:
2,"WDC 00000000002 ","WD-00000000002 ",“01.01A0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
2022.04.20 15:46:50 - INFO - RaidCfg64 detected 2 drives
2022.04.20 15:46:50 - INFO - RaidCfg64 drive WD-00000000002 : port=3
2022.04.20 15:46:50 - INFO - RaidCfg64 drive WD-00000000002 : port=2
2022.04.20 15:46:50 - WARN - No RAID volume detected!
2022.04.20 15:46:50 - INFO - Checking RAID status (1): Volume Missing
2022.04.20 15:46:51 - INFO - Detected drive 0 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.20 15:46:51 - INFO - Security: SUPPORTED
2022.04.20 15:46:51 - INFO - Enabled: 0
2022.04.20 15:46:51 - INFO - Locked: 0
2022.04.20 15:46:51 - INFO - Frozen: 0
2022.04.20 15:46:51 - INFO - Master Password Id supported: 1
2022.04.20 15:46:51 - INFO - Master Password Id: 0xFFFE
2022.04.20 15:46:51 - INFO - Master Password Capability: None
2022.04.20 15:46:51 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.20 15:46:51 - INFO - Enhanced Erase: 1
2022.04.20 15:46:51 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.20 15:46:51 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.20 15:46:51 - INFO - Detected drive 1 serial=WD-00000000002 2 model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.20 15:46:51 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.20 15:46:51 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.20 15:46:51 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.20 15:46:51 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x40000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
Disk 02 / 02
Disk: WDC WD4000F9YZ-09N20 SerialNo:WD-WCC1F0457392
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.20 15:46:51 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.20 15:46:51 - INFO - raidcfg64.exe /std Output:
2022.04.20 15:46:52 - INFO - RaidCfg64 detected 2 drives
2022.04.20 15:46:52 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=3
2022.04.20 15:46:52 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=2
2022.04.20 15:46:52 - WARN - No RAID volume detected!
2022.04.20 15:46:52 - INFO - Checking RAID status (2): Volume Missing
2022.04.20 15:46:53 - ERROR - Volume is not in good state, please re-create it
2022.04.20 15:46:53 - INFO - =========== Recovery app END (5) ===========
Wed 04/20/2022 21:45:17.59 Using platform STARGATE configuration
2022.04.20 21:45:17 - DEBUG - Reading resource file ‘C:\wdrecovery\Locale\en_US.xml’
2022.04.20 21:45:17 - INFO - =========== Recovery app START ===========
2022.04.20 21:45:17 - INFO - Version: 1.7.6.21
2022.04.20 21:45:17 - INFO - Loading configuration
2022.04.20 21:45:17 - DEBUG - Reading recovery configuration ‘C:\wdrecovery\recoverycfg.xml’
2022.04.20 21:45:17 - ERROR - Unable to open file C:\wdrecovery\recoverycfg.xml
2022.04.20 21:45:17 - ERROR - Failed to load recovery configuration: 1
2022.04.20 21:45:18 - DEBUG - Parsing whitelist ‘C:\wdrecovery\whitelist.xml’
2022.04.20 21:45:18 - DEBUG - Element: ‘WhiteList’ line 5
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 7
2022.04.20 21:45:18 - DEBUG - End element ‘Model’
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 8
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 9
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 10
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 13
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 14
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 17
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 18
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 19
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 20
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 21
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 23
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 24
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 25
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 26
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 27
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 29
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 30
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 31
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 32
2022.04.20 21:45:18 - DEBUG - Element: ‘Model’ line 33
2022.04.20 21:45:18 - DEBUG - End element ‘WhiteList’
2022.04.20 21:45:18 - DEBUG - Reading enclosure map ‘C:\wdrecovery\encmap.xml’
2022.04.20 21:45:18 - DEBUG - Element: ‘EnclosureMap’ line 7
2022.04.20 21:45:18 - DEBUG - Element: ‘DriveMap’ line 9
2022.04.20 21:45:18 - DEBUG - Element: ‘DriveMapEntry’ line 10
2022.04.20 21:45:18 - DEBUG - Element: ‘DriveMapEntry’ line 11
2022.04.20 21:45:18 - DEBUG - Element: ‘DriveMapEntry’ line 12
2022.04.20 21:45:18 - DEBUG - Element: ‘DriveMapEntry’ line 13
2022.04.20 21:45:18 - DEBUG - End element ‘DriveMap’
2022.04.20 21:45:18 - DEBUG - Element: ‘FanThrottle’ line 16
2022.04.20 21:45:18 - DEBUG - Element: ‘FanSpeed’ line 17
2022.04.20 21:45:18 - DEBUG - Element: ‘FanSpeed’ line 18
2022.04.20 21:45:18 - DEBUG - Element: ‘FanSpeed’ line 19
2022.04.20 21:45:18 - DEBUG - Element: ‘FanSpeed’ line 20
2022.04.20 21:45:18 - DEBUG - Element: ‘FanSpeed’ line 21
2022.04.20 21:45:18 - DEBUG - End element ‘FanThrottle’
2022.04.20 21:45:18 - DEBUG - Element: ‘EthernetPorts’ line 24
2022.04.20 21:45:18 - DEBUG - Element: ‘Port’ line 25
2022.04.20 21:45:18 - DEBUG - Element: ‘Port’ line 26
2022.04.20 21:45:18 - DEBUG - End element ‘EthernetPorts’
2022.04.20 21:45:18 - DEBUG - Element: ‘TemperatureStatus’ line 29
2022.04.20 21:45:18 - DEBUG - Element: ‘CPUTemp’ line 31
2022.04.20 21:45:18 - DEBUG - Element: ‘DriveTemp’ line 32
2022.04.20 21:45:18 - DEBUG - End element ‘TemperatureStatus’
2022.04.20 21:45:18 - DEBUG - Element: ‘FanSetting’ line 38
2022.04.20 21:45:18 - DEBUG - Element: ‘FanPWM’ line 39
2022.04.20 21:45:18 - DEBUG - Element: ‘FanPWM’ line 40
2022.04.20 21:45:18 - DEBUG - Element: ‘FanPWM’ line 41
2022.04.20 21:45:18 - DEBUG - End element ‘FanSetting’
2022.04.20 21:45:18 - DEBUG - Element: ‘Polling’ line 44
2022.04.20 21:45:18 - DEBUG - Element: ‘PowerSupply’ line 45
2022.04.20 21:45:18 - DEBUG - End element ‘Polling’
2022.04.20 21:45:18 - DEBUG - Element: ‘PowerSupplyMap’ line 48
2022.04.20 21:45:18 - DEBUG - Element: ‘PowerSupply’ line 49
2022.04.20 21:45:18 - DEBUG - Element: ‘PowerSupply’ line 50
2022.04.20 21:45:18 - DEBUG - End element ‘PowerSupplyMap’
2022.04.20 21:45:18 - DEBUG - End element ‘EnclosureMap’
2022.04.20 21:45:24 - INFO - In MS Recovery Mode
2022.04.20 21:45:24 - INFO - Detected drive 0 serial=WD-00000000002 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.20 21:45:24 - INFO - Security: SUPPORTED
2022.04.20 21:45:24 - INFO - Enabled: 0
2022.04.20 21:45:24 - INFO - Locked: 0
2022.04.20 21:45:24 - INFO - Frozen: 0
2022.04.20 21:45:24 - INFO - Master Password Id supported: 1
2022.04.20 21:45:24 - INFO - Master Password Id: 0xFFFE
2022.04.20 21:45:24 - INFO - Master Password Capability: None
2022.04.20 21:45:24 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.20 21:45:24 - INFO - Enhanced Erase: 1
2022.04.20 21:45:24 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.20 21:45:24 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.20 21:45:24 - INFO - Detected drive 1 serial=00000000002 model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.20 21:45:24 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.20 21:45:24 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.20 21:45:24 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.20 21:45:24 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
Disk: WDC WD4000F9YZ-09N20 SerialNo:WD-00000000002 V
State:(0x00000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.20 21:45:24 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.20 21:45:24 - INFO - raidcfg64.exe /std Output:
2,"WDC WD40000000000002 ","WD-WCC00000000002 ",“01.01A0”,-1,“Normal”,7814037168,7814037168,“ArrayMember”
3,"WDC WD400000000002 ","WD-00000000002 ",“01.01A0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
2022.04.20 21:45:24 - INFO - RaidCfg64 detected 2 drives
2022.04.20 21:45:24 - INFO - RaidCfg64 drive WD-00000000002 2: port=2
2022.04.20 21:45:24 - INFO - RaidCfg64 drive WD-00000000002 KVV: port=3
2022.04.20 21:45:24 - WARN - No RAID volume detected!
2022.04.20 21:45:24 - INFO - Checking RAID status (1): Volume Missing
2022.04.20 21:45:25 - INFO - Detected drive 0 serial=WD-00000000002 2 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.20 21:45:25 - INFO - Security: SUPPORTED
2022.04.20 21:45:25 - INFO - Enabled: 0
2022.04.20 21:45:25 - INFO - Locked: 0
2022.04.20 21:45:25 - INFO - Frozen: 0
2022.04.20 21:45:25 - INFO - Master Password Id supported: 1
2022.04.20 21:45:25 - INFO - Master Password Id: 0xFFFE
2022.04.20 21:45:25 - INFO - Master Password Capability: None
2022.04.20 21:45:25 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.20 21:45:25 - INFO - Enhanced Erase: 1
2022.04.20 21:45:25 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.20 21:45:25 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.20 21:45:25 - INFO - Detected drive 1 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.20 21:45:25 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.20 21:45:25 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.20 21:45:25 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.20 21:45:25 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x00000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.20 21:45:25 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.20 21:45:25 - INFO - raidcfg64.exe /std Output:
2,“WDC WD4000F9YZ-09N20”,“WD-00000000002 2”,“01.01A0”,-1,“Normal”,7814037168,7814037168,“ArrayMember”
3,“WDC WD4000F9YZ-09N20”,“WD-00000000002 V”,“01.01A0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
2022.04.20 21:45:25 - INFO - RaidCfg64 detected 2 drives
2022.04.20 21:45:25 - INFO - RaidCfg64 drive WD-00000000002: port=2
2022.04.20 21:45:25 - INFO - RaidCfg64 drive WD-0000000000V: port=3
2022.04.20 21:45:25 - WARN - No RAID volume detected!
2022.04.20 21:45:25 - INFO - Checking RAID status (2): Volume Missing
2022.04.20 21:45:26 - ERROR - Volume is not in good state, please re-create it
2022.04.20 21:45:27 - INFO - =========== Recovery app END (5) ===========
And this is the recreate storage log. it fails as soon as "create storage " appears
Thu 04/21/2022 9:39:34.10 Using platform STARGATE configuration
2022.04.21 09:39:34 - DEBUG - Reading resource file ‘C:\wdrecovery\Locale\en_US.xml’
2022.04.21 09:39:34 - INFO - =========== Recovery app START ===========
2022.04.21 09:39:34 - INFO - Version: 1.7.6.21
2022.04.21 09:39:34 - INFO - Loading configuration
2022.04.21 09:39:34 - DEBUG - Reading recovery configuration ‘C:\wdrecovery\recoverycfg.xml’
2022.04.21 09:39:34 - DEBUG - Element: ‘Recovery’ line 2
2022.04.21 09:39:34 - DEBUG - Element: ‘RecreateRaid’ line 3
2022.04.21 09:39:34 - DEBUG - End element ‘Recovery’
2022.04.21 09:39:34 - INFO - UnlockDrive: 0
2022.04.21 09:39:34 - INFO - PasswordValid: 0
2022.04.21 09:39:34 - INFO - RecreateRaid: 1
2022.04.21 09:39:34 - INFO - MSRecovery: 0
2022.04.21 09:39:34 - INFO - Locale is en_US
2022.04.21 09:39:35 - DEBUG - Parsing whitelist ‘C:\wdrecovery\whitelist.xml’
2022.04.21 09:39:35 - DEBUG - Element: ‘WhiteList’ line 5
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 7
2022.04.21 09:39:35 - DEBUG - End element ‘Model’
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 8
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 9
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 10
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 13
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 14
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 17
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 18
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 19
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 20
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 21
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 23
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 24
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 25
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 26
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 27
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 29
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 30
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 31
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 32
2022.04.21 09:39:35 - DEBUG - Element: ‘Model’ line 33
2022.04.21 09:39:35 - DEBUG - End element ‘WhiteList’
2022.04.21 09:39:35 - DEBUG - Reading enclosure map ‘C:\wdrecovery\encmap.xml’
2022.04.21 09:39:35 - DEBUG - Element: ‘EnclosureMap’ line 7
2022.04.21 09:39:35 - DEBUG - Element: ‘DriveMap’ line 9
2022.04.21 09:39:35 - DEBUG - Element: ‘DriveMapEntry’ line 10
2022.04.21 09:39:35 - DEBUG - Element: ‘DriveMapEntry’ line 11
2022.04.21 09:39:35 - DEBUG - Element: ‘DriveMapEntry’ line 12
2022.04.21 09:39:35 - DEBUG - Element: ‘DriveMapEntry’ line 13
2022.04.21 09:39:35 - DEBUG - End element ‘DriveMap’
2022.04.21 09:39:35 - DEBUG - Element: ‘FanThrottle’ line 16
2022.04.21 09:39:35 - DEBUG - Element: ‘FanSpeed’ line 17
2022.04.21 09:39:35 - DEBUG - Element: ‘FanSpeed’ line 18
2022.04.21 09:39:35 - DEBUG - Element: ‘FanSpeed’ line 19
2022.04.21 09:39:35 - DEBUG - Element: ‘FanSpeed’ line 20
2022.04.21 09:39:35 - DEBUG - Element: ‘FanSpeed’ line 21
2022.04.21 09:39:35 - DEBUG - End element ‘FanThrottle’
2022.04.21 09:39:35 - DEBUG - Element: ‘EthernetPorts’ line 24
2022.04.21 09:39:35 - DEBUG - Element: ‘Port’ line 25
2022.04.21 09:39:35 - DEBUG - Element: ‘Port’ line 26
2022.04.21 09:39:35 - DEBUG - End element ‘EthernetPorts’
2022.04.21 09:39:35 - DEBUG - Element: ‘TemperatureStatus’ line 29
2022.04.21 09:39:35 - DEBUG - Element: ‘CPUTemp’ line 31
2022.04.21 09:39:35 - DEBUG - Element: ‘DriveTemp’ line 32
2022.04.21 09:39:35 - DEBUG - End element ‘TemperatureStatus’
2022.04.21 09:39:35 - DEBUG - Element: ‘FanSetting’ line 38
2022.04.21 09:39:35 - DEBUG - Element: ‘FanPWM’ line 39
2022.04.21 09:39:35 - DEBUG - Element: ‘FanPWM’ line 40
2022.04.21 09:39:35 - DEBUG - Element: ‘FanPWM’ line 41
2022.04.21 09:39:35 - DEBUG - End element ‘FanSetting’
2022.04.21 09:39:35 - DEBUG - Element: ‘Polling’ line 44
2022.04.21 09:39:35 - DEBUG - Element: ‘PowerSupply’ line 45
2022.04.21 09:39:35 - DEBUG - End element ‘Polling’
2022.04.21 09:39:35 - DEBUG - Element: ‘PowerSupplyMap’ line 48
2022.04.21 09:39:35 - DEBUG - Element: ‘PowerSupply’ line 49
2022.04.21 09:39:35 - DEBUG - Element: ‘PowerSupply’ line 50
2022.04.21 09:39:35 - DEBUG - End element ‘PowerSupplyMap’
2022.04.21 09:39:35 - DEBUG - End element ‘EnclosureMap’
2022.04.21 09:39:42 - INFO - Detected drive 0 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.21 09:39:42 - INFO - Security: SUPPORTED
2022.04.21 09:39:42 - INFO - Enabled: 0
2022.04.21 09:39:42 - INFO - Locked: 0
2022.04.21 09:39:42 - INFO - Frozen: 0
2022.04.21 09:39:42 - INFO - Master Password Id supported: 1
2022.04.21 09:39:42 - INFO - Master Password Id: 0xFFFE
2022.04.21 09:39:42 - INFO - Master Password Capability: None
2022.04.21 09:39:42 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.21 09:39:42 - INFO - Enhanced Erase: 1
2022.04.21 09:39:42 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.21 09:39:42 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.21 09:39:42 - INFO - Detected drive 1 serial=WD-00000000002 V model=WDC WD400000000002 L1 SATA=3 led=1
2022.04.21 09:39:42 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.21 09:39:42 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.21 09:39:42 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.21 09:39:42 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x00000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.21 09:39:42 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.21 09:39:42 - INFO - raidcfg64.exe /std Output:
2,“WDC WD00000000002 0”,"WD-W00000000002 ",“01.01A0”,-1,“Normal”,7814037168,7814037168,“ArrayMember”
3,“WDC 00000000002 0”,“WD-W00000000002 V”,“01.01A0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
2022.04.21 09:39:42 - INFO - RaidCfg64 detected 2 drives
2022.04.21 09:39:42 - INFO - RaidCfg64 drive WD-00000000002 2: port=2
2022.04.21 09:39:42 - INFO - RaidCfg64 drive WD-00000000002 V: port=3
2022.04.21 09:39:42 - INFO - Matched drive 0 serial WD-00000000002 2 model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.21 09:39:42 - INFO - Matched drive 1 serial WD-00000000002 model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.21 09:39:44 - INFO - Detected drive 0 serial=WD-00000000002 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.21 09:39:44 - INFO - Security: SUPPORTED
2022.04.21 09:39:44 - INFO - Enabled: 0
2022.04.21 09:39:44 - INFO - Locked: 0
2022.04.21 09:39:44 - INFO - Frozen: 0
2022.04.21 09:39:44 - INFO - Master Password Id supported: 1
2022.04.21 09:39:44 - INFO - Master Password Id: 0xFFFE
2022.04.21 09:39:44 - INFO - Master Password Capability: None
2022.04.21 09:39:44 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.21 09:39:44 - INFO - Enhanced Erase: 1
2022.04.21 09:39:44 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.21 09:39:44 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.21 09:39:44 - INFO - Detected drive 1 serial=WD-00000000002 model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.21 09:39:44 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.21 09:39:44 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.21 09:39:44 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.21 09:39:44 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x00000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.21 09:39:44 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.21 09:39:44 - INFO - raidcfg64.exe /std Output:
2,“WDC WD4000F9YZ-09N20”,"WD-00000000002 ",“01.01A0”,-1,“Normal”,7814037168,7814037168,“ArrayMember”
3,“WDC WD4000F9YZ-09N20”,"WD-00000000002 ",“01.01A0”,-1,“Normal”,7814037168,7814037168,“Passthrough”
2022.04.21 09:39:44 - INFO - RaidCfg64 detected 2 drives
2022.04.21 09:39:44 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=2
2022.04.21 09:39:44 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=3
2022.04.21 09:39:44 - WARN - No RAID volume detected!
2022.04.21 09:39:44 - INFO - Checking RAID status (1): Volume Missing
2022.04.21 09:39:45 - INFO - Detected drive 0 serial=WD-00000000002 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.21 09:39:45 - INFO - Security: SUPPORTED
2022.04.21 09:39:45 - INFO - Enabled: 0
2022.04.21 09:39:45 - INFO - Locked: 0
2022.04.21 09:39:45 - INFO - Frozen: 0
2022.04.21 09:39:45 - INFO - Master Password Id supported: 1
2022.04.21 09:39:45 - INFO - Master Password Id: 0xFFFE
2022.04.21 09:39:45 - INFO - Master Password Capability: None
2022.04.21 09:39:45 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.21 09:39:45 - INFO - Enhanced Erase: 1
2022.04.21 09:39:45 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.21 09:39:45 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.21 09:39:45 - INFO - Detected drive 1 serial=WD-00000000002 model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.21 09:39:45 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.21 09:39:45 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.21 09:39:45 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.21 09:39:45 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x00000538)
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x00000458)
USABLE_DISK
DETECTED_DISK
PASSTHRU_DISK
RAID Volumes
Total Volumes = 0
RAID Arrays
Total Arrays = 0
2022.04.21 09:39:45 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.21 09:39:45 - INFO - raidcfg64.exe /std Output:
2022.04.21 09:39:45 - INFO - RaidCfg64 detected 2 drives
2022.04.21 09:39:45 - INFO - RaidCfg64 drive WD-00000000002 : port=2
2022.04.21 09:39:45 - INFO - RaidCfg64 drive WD-00000000002 : port=3
2022.04.21 09:39:45 - WARN - No RAID volume detected!
2022.04.21 09:39:45 - INFO - Checking RAID status (2): Volume Missing
2022.04.21 09:39:46 - WARN - RAID volume status is bad or volume is missing, need to re-create the RAID volume: Volume Missing
2022.04.21 09:39:47 - INFO - Deleting all RAID volumes
2022.04.21 09:39:51 - INFO - Re-creating RAID volume
2022.04.21 09:39:51 - INFO - C:\wdrecovery\raidcfg64.exe /Y /c:Volume0 /l:1 /ds:2 3
2022.04.21 09:39:52 - INFO - raidcfg64.exe output
2022.04.21 09:39:52 - ERROR - Failed to create RAID: exit code = 1
2022.04.21 09:39:52 - ERROR - Failed to create RAID volume: RaidCfg Util Error
2022.04.21 09:39:52 - INFO - =========== Recovery app END (4) ===========
Are you recreating the thumb drive each time you boot from it?
diskpart clean
recreate thumb drive
boot with it
yup doing it every time.
ive tried changing the slots, still does exactly the same.
ive not done anything different, yet it worked on saturday but now it fails at every attempt
Yea I noticed that the discs changed.
That passthrough disc.
So are both of these discs ones that came with the box originally?
For giggles try a different brand thumb drive.
no not ones that came with it, but were from the small batch that are allowed with it originally.
ill try new T/drive now
Update
Tried different T/drive same result
I am not sure what happened in this one. I think he may have tried diff slots but toward the end is a link for a good recreate. No passthrough disc He also claims to have done some kind of heavy duty erase.
ill download the files in the thread and try, but files i already have worked on saturday but dont work now if its the recovery image thats the problem.
I was not really saying to download diff files, I think it was diff slots. But I do not suppose it could hurt at this point to download.
That said you are “mounting” the iso not burning to a dvd ?
Once you do diskpart> clean you just eject the drive, no format? I can’t figure out why one drive gets listed as passthrough
ah, got ya ive picked you up wrong.
Yes mounting the iso and running it from the virtual drive.
yeah do diskpart, clean and then eject the hdd from pc.ive tried formatting them ive tried putting it to mbr gpt etc etc and it always fails.
there was one strange thing that happened, drive 1 was split in to two partitions split roughly 50/50 deleted the partition put through diskpart and cleaned failed at creation part
put them back in and run a new recreate the drives.
im as lost as you, when i followed your advice on saturday worked like a dream, now its failing at every attempt
update
so had tried the options over and over again with zero luck
so dug out a old buffalo terastation ive held on to, put the two hdds in to terastation. wouldnt mount wouldnt register but would spin up and try to load.
i think the raid 5 on the tera was possibly the reason this was happening
so before i went mad and threw the sentinal against a wall out of frustration i decided to give it one last try.
took the drives from the terastation put them straight in to sentinel dindt diskpart them.
tried recreate drives built new usb and loaded success
created recovery usb success now loading the recovery image on to sentinel
hopefully ive not jinxed myself.
update
recovery image loaded successfully
just finishing the install and so far so good
do you have the logs from the recreate? just curious if it no longer said passthrough
sadly not as i used the same thumbdrive for recreate and recovery. didnt want to tempt fate by using another thumbdrive.
it wasnt till i started creating the recovery usb that i remembered about the logs, sorry.
Appreciated your help
so when recovery was finished it appears there was a problem with one of the drives, ive managed to reinstall server and get it up and running. new disc is in and currently migrating so all appears to be good.
I don’t suppose you have any idea if the bad drive was the one that kept getting labeled passthrough do you?
If you can find your whitelist.xml file after you ran the drive enabler it basically allows all drives
something like [WDC*.*]
Then replace that file in the 2 thumb drives as well as I think it has to be changed in the ISO
Changing the ISO is the tricky part
fortunately I’ve run in to another hurdle and had to start all over again.
so kept the recreate log file for you to see.
Wed 04/27/2022 16:21:10.27 Using platform STARGATE configuration
2022.04.27 16:21:10 - DEBUG - Reading resource file ‘C:\wdrecovery\Locale\en_US.xml’
2022.04.27 16:21:10 - INFO - =========== Recovery app START ===========
2022.04.27 16:21:10 - INFO - Version: 1.7.6.21
2022.04.27 16:21:10 - INFO - Loading configuration
2022.04.27 16:21:10 - DEBUG - Reading recovery configuration ‘C:\wdrecovery\recoverycfg.xml’
2022.04.27 16:21:10 - DEBUG - Element: ‘Recovery’ line 2
2022.04.27 16:21:10 - DEBUG - Element: ‘RecreateRaid’ line 3
2022.04.27 16:21:10 - DEBUG - End element ‘Recovery’
2022.04.27 16:21:10 - INFO - UnlockDrive: 0
2022.04.27 16:21:10 - INFO - PasswordValid: 0
2022.04.27 16:21:10 - INFO - RecreateRaid: 1
2022.04.27 16:21:10 - INFO - MSRecovery: 0
2022.04.27 16:21:10 - INFO - Locale is en_US
2022.04.27 16:21:11 - DEBUG - Parsing whitelist ‘C:\wdrecovery\whitelist.xml’
2022.04.27 16:21:11 - DEBUG - Element: ‘WhiteList’ line 5
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 7
2022.04.27 16:21:11 - DEBUG - End element ‘Model’
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 8
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 9
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 10
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 13
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 14
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 17
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 18
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 19
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 20
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 21
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 23
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 24
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 25
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 26
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 27
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 29
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 30
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 31
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 32
2022.04.27 16:21:11 - DEBUG - Element: ‘Model’ line 33
2022.04.27 16:21:11 - DEBUG - End element ‘WhiteList’
2022.04.27 16:21:11 - DEBUG - Reading enclosure map ‘C:\wdrecovery\encmap.xml’
2022.04.27 16:21:11 - DEBUG - Element: ‘EnclosureMap’ line 7
2022.04.27 16:21:11 - DEBUG - Element: ‘DriveMap’ line 9
2022.04.27 16:21:11 - DEBUG - Element: ‘DriveMapEntry’ line 10
2022.04.27 16:21:11 - DEBUG - Element: ‘DriveMapEntry’ line 11
2022.04.27 16:21:11 - DEBUG - Element: ‘DriveMapEntry’ line 12
2022.04.27 16:21:11 - DEBUG - Element: ‘DriveMapEntry’ line 13
2022.04.27 16:21:11 - DEBUG - End element ‘DriveMap’
2022.04.27 16:21:11 - DEBUG - Element: ‘FanThrottle’ line 16
2022.04.27 16:21:11 - DEBUG - Element: ‘FanSpeed’ line 17
2022.04.27 16:21:11 - DEBUG - Element: ‘FanSpeed’ line 18
2022.04.27 16:21:11 - DEBUG - Element: ‘FanSpeed’ line 19
2022.04.27 16:21:11 - DEBUG - Element: ‘FanSpeed’ line 20
2022.04.27 16:21:11 - DEBUG - Element: ‘FanSpeed’ line 21
2022.04.27 16:21:11 - DEBUG - End element ‘FanThrottle’
2022.04.27 16:21:11 - DEBUG - Element: ‘EthernetPorts’ line 24
2022.04.27 16:21:11 - DEBUG - Element: ‘Port’ line 25
2022.04.27 16:21:11 - DEBUG - Element: ‘Port’ line 26
2022.04.27 16:21:11 - DEBUG - End element ‘EthernetPorts’
2022.04.27 16:21:11 - DEBUG - Element: ‘TemperatureStatus’ line 29
2022.04.27 16:21:11 - DEBUG - Element: ‘CPUTemp’ line 31
2022.04.27 16:21:11 - DEBUG - Element: ‘DriveTemp’ line 32
2022.04.27 16:21:11 - DEBUG - End element ‘TemperatureStatus’
2022.04.27 16:21:11 - DEBUG - Element: ‘FanSetting’ line 38
2022.04.27 16:21:11 - DEBUG - Element: ‘FanPWM’ line 39
2022.04.27 16:21:11 - DEBUG - Element: ‘FanPWM’ line 40
2022.04.27 16:21:11 - DEBUG - Element: ‘FanPWM’ line 41
2022.04.27 16:21:11 - DEBUG - End element ‘FanSetting’
2022.04.27 16:21:11 - DEBUG - Element: ‘Polling’ line 44
2022.04.27 16:21:11 - DEBUG - Element: ‘PowerSupply’ line 45
2022.04.27 16:21:11 - DEBUG - End element ‘Polling’
2022.04.27 16:21:11 - DEBUG - Element: ‘PowerSupplyMap’ line 48
2022.04.27 16:21:11 - DEBUG - Element: ‘PowerSupply’ line 49
2022.04.27 16:21:11 - DEBUG - Element: ‘PowerSupply’ line 50
2022.04.27 16:21:11 - DEBUG - End element ‘PowerSupplyMap’
2022.04.27 16:21:11 - DEBUG - End element ‘EnclosureMap’
2022.04.27 16:21:19 - INFO - Detected drive 0 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.27 16:21:19 - INFO - Security: SUPPORTED
2022.04.27 16:21:19 - INFO - Enabled: 0
2022.04.27 16:21:19 - INFO - Locked: 0
2022.04.27 16:21:19 - INFO - Frozen: 0
2022.04.27 16:21:19 - INFO - Master Password Id supported: 1
2022.04.27 16:21:19 - INFO - Master Password Id: 0xFFFE
2022.04.27 16:21:19 - INFO - Master Password Capability: None
2022.04.27 16:21:19 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.27 16:21:19 - INFO - Enhanced Erase: 1
2022.04.27 16:21:19 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.27 16:21:19 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.27 16:21:19 - INFO - Detected drive 1 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.27 16:21:19 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.27 16:21:19 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.27 16:21:19 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.27 16:21:19 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
Description:00F9YZ-09N20 Summary:Array Member
Rev:01.01A0 Summary:Array Member
FreeBlks:0x875F TotalBlks:0x1D1C0BEB0
BusId:0x00000002 TargetId:0x00000000 LUN:0x00000000 Array:0x00
Partitions:02 CheckBox:0x00000000 CfgStatus:(00) Ok
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
Disk: WDC WD4000F9YZ-09N20 SerialNo:WD-WCC5D7T66KVV
BusId:0x00000003 TargetId:0x00000000 LUN:0x00000000 Array:0x00
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Volume 01 / 01
SerialNo:Volume0 Summary:Failed
RaidLevel: 5 MemberDisks:04 Domains/Mirrors:01 TargetId:0x01
SizeInMB:11446291 BytesPerBlock:0x00000200 StripSize: 64KB
Action:00 Array:00 MapState:03 MigrState:00 MigrType:01 CfgStatus:0x00000000
Total Volumes = 1
RAID Arrays
Array 01 / 01
NumDisks:04 RAIDDevs:01 TotalMB:15261790 FreeMB:67
State:00 CheckBox:0x00000000
Total Arrays = 1
2022.04.27 16:21:19 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.27 16:21:19 - INFO - raidcfg64.exe /std Output:
2,“WDC WD4000F9YZ-09N20”,“WD-WCC1F0457392”,“01.01A0”,0,“Normal”,7814037168,34655,“ArrayMember”
3,“WDC WD4000F9YZ-09N20”,“WD-WCC5D7T66KVV”,“01.01A0”,0,“Normal”,7814037168,34655,“ArrayMember”
2022.04.27 16:21:19 - INFO - RaidCfg64 detected 2 drives
2022.04.27 16:21:19 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=2
2022.04.27 16:21:19 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=3
2022.04.27 16:21:19 - INFO - Matched drive 0 serial WD-WCC1F0457392 model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:19 - INFO - Matched drive 1 serial WD-WCC5D7T66KVV model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:21 - INFO - Detected drive 0 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.27 16:21:21 - INFO - Security: SUPPORTED
2022.04.27 16:21:21 - INFO - Enabled: 0
2022.04.27 16:21:21 - INFO - Locked: 0
2022.04.27 16:21:21 - INFO - Frozen: 0
2022.04.27 16:21:21 - INFO - Master Password Id supported: 1
2022.04.27 16:21:21 - INFO - Master Password Id: 0xFFFE
2022.04.27 16:21:21 - INFO - Master Password Capability: None
2022.04.27 16:21:21 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.27 16:21:21 - INFO - Enhanced Erase: 1
2022.04.27 16:21:21 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.27 16:21:21 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.27 16:21:21 - INFO - Detected drive 1 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.27 16:21:21 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.27 16:21:21 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.27 16:21:21 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.27 16:21:21 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Volume 01 / 01
Total Volumes = 1
RAID Arrays
Array 01 / 01
Total Arrays = 1
2022.04.27 16:21:21 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.27 16:21:21 - INFO - raidcfg64.exe /std Output:
2022.04.27 16:21:21 - INFO - RaidCfg64 detected 2 drives
2022.04.27 16:21:21 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=2
2022.04.27 16:21:21 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=3
2022.04.27 16:21:21 - INFO - RAID volume status is ‘FAILED’!
2022.04.27 16:21:21 - INFO - Matched drive 0 serial WD-WCC1F0457392 model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:21 - INFO - Matched drive 1 serial WD-WCC5D7T66KVV model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:21 - INFO - Checking RAID status (1): Volume Failed
2022.04.27 16:21:22 - INFO - Detected drive 0 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.27 16:21:22 - INFO - Security: SUPPORTED
2022.04.27 16:21:22 - INFO - Enabled: 0
2022.04.27 16:21:22 - INFO - Locked: 0
2022.04.27 16:21:22 - INFO - Frozen: 0
2022.04.27 16:21:22 - INFO - Master Password Id supported: 1
2022.04.27 16:21:22 - INFO - Master Password Id: 0xFFFE
2022.04.27 16:21:22 - INFO - Master Password Capability: None
2022.04.27 16:21:22 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.27 16:21:22 - INFO - Enhanced Erase: 1
2022.04.27 16:21:22 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.27 16:21:22 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.27 16:21:22 - INFO - Detected drive 1 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.27 16:21:22 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.27 16:21:22 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.27 16:21:22 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.27 16:21:22 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Volume 01 / 01
Total Volumes = 1
RAID Arrays
Array 01 / 01
Total Arrays = 1
2022.04.27 16:21:22 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.27 16:21:22 - INFO - raidcfg64.exe /std Output:
2022.04.27 16:21:22 - INFO - RaidCfg64 detected 2 drives
2022.04.27 16:21:22 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=2
2022.04.27 16:21:22 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=3
2022.04.27 16:21:22 - INFO - RAID volume status is ‘FAILED’!
2022.04.27 16:21:22 - INFO - Matched drive 0 serial WD-WCC1F0457392 model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:22 - INFO - Matched drive 1 serial WD-WCC5D7T66KVV model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:22 - INFO - Checking RAID status (2): Volume Failed
2022.04.27 16:21:23 - WARN - RAID volume status is bad or volume is missing, need to re-create the RAID volume: Volume Failed
2022.04.27 16:21:24 - INFO - Deleting all RAID volumes
2022.04.27 16:21:24 - INFO - C:\wdrecovery\raidcfg64.exe /Y /d:Volume0
2022.04.27 16:21:26 - INFO - raidcfg64.exe output
Delete RAID Volume…
Deleting Volume “Volume0”…Deleted
2022.04.27 16:21:26 - INFO - Deleted RAID volume ‘Volume0’
2022.04.27 16:21:31 - INFO - Re-creating RAID volume
2022.04.27 16:21:31 - INFO - C:\wdrecovery\raidcfg64.exe /Y /c:Volume0 /l:1 /ds:2 3
2022.04.27 16:21:34 - INFO - raidcfg64.exe output
Creating Volume…
Volume Name: “Volume0”
RAID Level: 1
Strip Size: 64KB
Ports Selected: Disk(Port:2) Disk(Port:3)
Creating Volume…Successfully Created Volume
2022.04.27 16:21:38 - INFO - Restart IAStor driver: C:\wdrecovery\devcon.exe restart “PCI\VEN_8086&DEV_2822”
2022.04.27 16:21:38 - INFO - Unload CSMI first
2022.04.27 16:21:38 - INFO - ReInitialize CSMI
2022.04.27 16:21:43 - INFO - Detected drive 0 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.27 16:21:43 - INFO - Security: SUPPORTED
2022.04.27 16:21:43 - INFO - Enabled: 0
2022.04.27 16:21:43 - INFO - Locked: 0
2022.04.27 16:21:43 - INFO - Frozen: 0
2022.04.27 16:21:43 - INFO - Master Password Id supported: 1
2022.04.27 16:21:43 - INFO - Master Password Id: 0xFFFE
2022.04.27 16:21:43 - INFO - Master Password Capability: None
2022.04.27 16:21:43 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.27 16:21:43 - INFO - Enhanced Erase: 1
2022.04.27 16:21:43 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.27 16:21:43 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.27 16:21:43 - INFO - Detected drive 1 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.27 16:21:43 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.27 16:21:43 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.27 16:21:43 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.27 16:21:43 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
FreeBlks:0x130F TotalBlks:0x1D1C0BEB0
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Volume 01 / 01
SerialNo:Volume0 Summary:Normal
RaidLevel: 1 MemberDisks:02 Domains/Mirrors:02 TargetId:0x01
SizeInMB:3815445 BytesPerBlock:0x00000200 StripSize: 64KB
Action:00 Array:00 MapState:00 MigrState:00 MigrType:00 CfgStatus:0x00000000
Total Volumes = 1
RAID Arrays
Array 01 / 01
NumDisks:02 RAIDDevs:01 TotalMB:7630895 FreeMB:4
Total Arrays = 1
2022.04.27 16:21:43 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.27 16:21:43 - INFO - raidcfg64.exe /std Output:
2,“WDC WD4000F9YZ-09N20”,“WD-WCC1F0457392”,“01.01A0”,0,“Normal”,7814037168,4879,“ArrayMember”
3,“WDC WD4000F9YZ-09N20”,“WD-WCC5D7T66KVV”,“01.01A0”,0,“Normal”,7814037168,4879,“ArrayMember”
2022.04.27 16:21:43 - INFO - RaidCfg64 detected 2 drives
2022.04.27 16:21:43 - INFO - RaidCfg64 drive WD-WCC1F0457392: port=2
2022.04.27 16:21:43 - INFO - RaidCfg64 drive WD-WCC5D7T66KVV: port=3
2022.04.27 16:21:43 - INFO - Matched drive 0 serial WD-WCC1F0457392 model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:43 - INFO - Matched drive 1 serial WD-WCC5D7T66KVV model WDC WD4000F9YZ-09N20L1 with white list entry Enterprise Storage 4 TB
2022.04.27 16:21:43 - INFO - Checking RAID status (1): Volume Good
2022.04.27 16:21:44 - INFO - Detected drive 0 serial=WD-WCC1F0457392 model=WDC WD4000F9YZ-09N20L1 SATA=2 led=0
2022.04.27 16:21:44 - INFO - Security: SUPPORTED
2022.04.27 16:21:44 - INFO - Enabled: 0
2022.04.27 16:21:44 - INFO - Locked: 0
2022.04.27 16:21:44 - INFO - Frozen: 0
2022.04.27 16:21:44 - INFO - Master Password Id supported: 1
2022.04.27 16:21:44 - INFO - Master Password Id: 0xFFFE
2022.04.27 16:21:44 - INFO - Master Password Capability: None
2022.04.27 16:21:44 - INFO - Unlock Attempt Counter Exceeded: 0
2022.04.27 16:21:44 - INFO - Enhanced Erase: 1
2022.04.27 16:21:44 - INFO - Erase Time: Normal (raw 215; 25800 sec)
2022.04.27 16:21:44 - INFO - Erase Time: Enhanced (raw 215; 25800 sec)
2022.04.27 16:21:44 - INFO - Detected drive 1 serial=WD-WCC5D7T66KVV model=WDC WD4000F9YZ-09N20L1 SATA=3 led=1
2022.04.27 16:21:44 - INFO - Erase Time: Normal (raw 223; 26760 sec)
2022.04.27 16:21:44 - INFO - Erase Time: Enhanced (raw 223; 26760 sec)
2022.04.27 16:21:44 - INFO - C:\wdrecovery\raidcfg64.exe /i
2022.04.27 16:21:44 - INFO - raidcfg64.exe /i Output:
Version Tables:
Disk 01 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 02 / 02
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
RAID Volumes
Volume 01 / 01
Total Volumes = 1
RAID Arrays
Array 01 / 01
Total Arrays = 1
2022.04.27 16:21:44 - INFO - C:\wdrecovery\raidcfg64.exe /std
2022.04.27 16:21:44 - INFO - raidcfg64.exe /std Output:
