Repository with software worked on v4 firmware
Well, got a little further with the subversion compiling…
Got as far as successfully compiling the Subversion package version 1.8.10…
(link to compiled .deb file)
Yet
For some reason it did not compile the mod_dav_svn.so & mod_authz.svn.so files with it…
Tried to compile Apache2 for our firmware in hope that I could recompile subversion after including the .so files, but apache2 requires OpenSSL, which on itself apparently required BerkeleyDB. And I fail to properly install BerkeleyDB…
Any way you can help me out with this or have the ability to compile the .so files yourself?
I would very much appreciate it @Fox_exe
I cant compile libgcc++6 (glibc) on Jessie, so i cant prepare full jessie repository. Its usable only for upgrade packages in wheezy chroot…
About Subversion and git - Have some errors too… Maybe i cant compile dependencies… Maybe can… Just wait…
I have actually figured out OpenSSL now, I think, trying to compile Apache2/httpd now, hoping I can then recompile subversion including the .so files.
Will post here if I succeed.
EDIT:
So far, failed every attempt to build httpd… Having errors with among others gen_test_char. Without recompiling httpd I cannot recompile subversion with the mod file, and thus I wont be able to run svnserve with apache2…
I did recompile the subversion package itself, since I had used the wrong sqlite3 version as dependency the last time (will post new .deb later).
Current tests end up with svn telling me ‘Segmentation fault’ on every attampt to commit anything to the svn repo on my My Cloud.
So, my current subversion package IS installable on wheezy-64k, svnserve DOES run, yet I cannot commit or access the repo from another machine yet…
Will post if I book more progress.
https://www.mobibrw.com/p=1554
Its helps me a lot! Jessie+OMV+64k patch now is possible.
Subversion will be soon.
And i stop build anything for Wheezy.
Any chance you can compile GDB instead?
I’ve got subversion successfully compiled including the mod .so files, but still get the Segmentation Fault errors when trying to commit and such on the WD My Cloud device…
With GDB I would be able to debug why and fix accordingly, yet GDB compilation fails due to it being unable to find the termcap library, which I DO have installed …
So to be clear, I HAVE subversion… Just can’t run it properly yet.
Cheers.
EDIT: I think I figured it out… I’ve got an svn server running fine now.
Hi Fox_exe,
Again thanks, for all your hard work in making WD my Cloud a usable purchase!
Please Could I make a request for Transmission 2.92 (Latest) to be added to repo.
Many thanks!
Hallo Fox_exe,
great repository. Thanks! My request is calibre. This would be great. Calibre has an in-build-server for presenting the ebook-library via wlan und WDMylcoud.
Many thanks
blakeholeone
Hi @Fox_exe is sickrage avialable in this repo ? i eagerly want it :0
Don’t think it is, but you can get it here [APP] SickRage various versions for firmware V4+ (02/2016)
Hope this helps.
Please, please, please add qbittorrent…
Why does my NAS use BusyBox?? ■■■■!! :cry:
Because you have a gen2 My Cloud. They changed things in the gen2.
RAC
I have now gone through the process of creating an Ubuntu machine to do a 64K page file build of qbittorrent and libtorrent-rasterbar and while the compile finished it is a .tar.gz is so small it just can’t be right. I’m really stuck. Can anyone please PM me what I need to be able to install qbittorrent to my WD My Cloud Mirror Gen 2?
I’m on the newest firmware on WD My Cloud and after update when I’ve added Your repo to source.list and doing apt-get update I’m getting following:
WDMyCloud:/shares/Public/programs/napisy/napisy linux# apt-get update
Ign http://anionix.ddns.net wheezy-64k Release.gpg
Err http://anionix.ddns.net wheezy-64k/main armhf Packages
301 Moved Permanently
Ign http://anionix.ddns.net wheezy-64k/main Translation-en
W: Failed to fetch http://anionix.ddns.net/dists/wheezy-64k/main/binary-armhf/Packages 301 Moved Permanently
E: Some index files failed to download. They have been ignored, or old ones used instead.
Any ideas what is going on? Thanks for help in advance.
Sorry.
anionix.ddns.net moved to http://ftp.anionix.ru
Main site under construction (https://anionix.ru)
(wget wors correct with “redirect 301”, but apt can’t…)
Thanks, now everything works perfect :slight_smile:
Hi, All
I try to install chroot:
KAV-WDMyCloud:/home# wget anionix.ru
KAV-WDMyCloud:/home# sh chroot_for_v4-wheezy_install.sh
But the installation process get errors:
W: Failure trying to run: chroot /DataVolume/debian dpkg --force-depends --install /var/cache/apt/archives/base-passwd_3.5.26_armhf.deb
W: See /DataVolume/debian/debootstrap/debootstrap.log for details (possibly the package udev is at fault)
sed: can’t read /DataVolume/debian/etc/locale.gen: No such file or directory
chroot: failed to run command `locale-gen’: No such file or directory
Info: A Debian wheezy chroot environment installed.
Info: Now deploying services start script…
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match chroot_debian.sh Default-Stop values (0 6)
And finally when try to install transmission:
=> Do you wish to install Transmission BitTorrent client [y/n]?y
Info: Torrents content will be downloaded to “Public/Torrents” share. Installing…
chroot: failed to run command `apt-get’: No such file or directory
What am I doing wrong?
Sorry, my web server is down, i recover it from backup and there is no few files (awk package and other stuff). So - Repo not full and can’t be installed.
I write a message when i fix it.
Waiting…
Hello
I want to install Subversion on WD My Cloud Gen1. But when I try to install it, apt-get does not find some libs (for example libexpat1, libapr1, libserf …) Can you re-compile it for me?
I will be very grateful!!! Thank you
