No the DX4200 is Storage Server 2012R2 not the same as the DX4000
You should do backups of the 4200…
The data on there is backups of the vmware servers. Do you mean to backup the DX4200 2012 OS? I guess I had not thought that necessary but I probably should if I can’t get the iso image.
yea, I meant backup the c: drive and it actually had a recovery partition on it, but that did not make much sense as you had to restart from windows to get to it.
I suppose if you are doing a clean install of c: to get to your storage pools you could actually install the 180 demo of server 2012R2 just to get your data.
