Hi guys,
I use Raid 1 on my cloud ex2.
I have something weird going on. When i received mine My Cloud ex2 with dual wd red of 6tb disks i just unpack all the gear and just do the installation as provided. I used also the data cable that was inluced in the box and i connect it to mine Airport Extreme router from apple. Also mine computer is windows and is also connected on the Airport extreme and if i do a speedtest of mine connection via this website www.speedtest.net. below you see a picture of it. The problem i have with mine My cloud device is i wanted to copy mine files from a wd 4tb external disk wich is connected on my pc via USB 3 connection from there i copy them to mine Wd my cloud ex2 drive via network and i try to move arround 50gigs in total and he write them in aprox 10MB/s thats ridicilous slow speed. How i can solve this issue /? is there any way to do it faster because i also wanted my movies on the nas but if i see that 50 gigs takes me aprox 2 hours to get the job done ya mine USB 3 external disk do this operation much quicker… pfff
I checked also mine network and i have 1Gb speed and the network light at the back of the mycloud ex2 is GREEN blinking because of the copy proces…
Anyone can give me explanation about this matter
Thanks in advance
Steve
